Will i have a problem fitting these wheels?
Old 04-20-2009, 11:19 AM
xRelapse13's Avatar
Default Will i have a problem fitting these wheels?
18x9.5 120mm 35offset
Besides the hubcentric rings i'll need, will i have a problem fitting these wheels?
Old 04-20-2009, 11:29 AM
ben77's Avatar
I think you'll be ok with those, sounds like they'll sit almost flush with the fender.
Old 04-20-2009, 11:49 AM
Xsta Z 28's Avatar
Should be OK on a 'bird, but the bolt pattern is technically wrong . . . 120.65 is the actual bolt pattern.
I would not run 35 mm offset on a Camaro though . . . 38 mm is the max there.
Old 04-20-2009, 12:29 PM
xRelapse13's Avatar
good to hear, finally found wheels i like that will fit. I'll be getting hub centric rings and its a bird so sounds like i should be good.
Old 04-20-2009, 02:12 PM
LS1W66's Avatar
Heres a pic of my Bird with 18x8.5 fronts (stock ride height)
Now keep in mind that your suggested 9.5" wide wheels will stick out another 1/2".
At that point you may have issues when the wheel is at full jounce.
Just wanted to make you aware.
Old 04-20-2009, 04:49 PM
xRelapse13's Avatar
thanks for the pic man. It'll be close, we'll see, the car will also be dropped on strano springs. If anything i can always roll the fenders a bit.
Or if all else fails return the wheels lol.
Old 04-20-2009, 07:16 PM
LS1W66's Avatar
Strano's huh well here you go the same car on Strano's with Koni's
Oh yeah forgot to mention my wheels are 35mm offset aswell F & R
Old 04-20-2009, 09:32 PM
nick1ta's Avatar
that's sex!
Old 04-20-2009, 10:12 PM
xRelapse13's Avatar
u just confirmed my decision to buy the rims
