rear pro stars wont fit on my moser 12 bolt please help. Moser Guys Come In
Old 05-09-2009, 12:38 PM
95transamlt1's Avatar
Default rear pro stars wont fit on my moser 12 bolt please help. Moser Guys Come In
I have a set of rear pro stars in 15x10 with 7.5 backspacing for f bodys, I had run them on my car before with no issues when i had my 10 bolt rear end i just had to grind the stock calipers like usual with the proper spacer and they fit right up no problems. but now that i have my 12 bolt with the stock calipers that i had previously grinded and i try to put my pro stars on and the wheel goes on but rubs a bit. Do you guys think i just need to grind more of the caliper. what do you moser guys run back there. thanks alot .
Old 05-09-2009, 04:47 PM
ls1ow's Avatar
if the axle is the same length, then there rear would have nothing to do with it, i would just grind the caliber more, you should grind it till you have to run NO spacer in the rear.
Old 05-09-2009, 06:06 PM
'Trust''s Avatar
Out of curiosity, you don't live in Oklahoma do you?
Old 05-09-2009, 10:51 PM
kilrbecars1's Avatar
Keep grinding Bro!
Old 05-09-2009, 11:34 PM
02BLKWS6MD's Avatar
If it only needs a little grinding I would it grind it until it fits.
Old 05-10-2009, 01:41 AM
no i dont live in oaklahoma, but i think it just needs a little bit of grinding on the caliper. I will try that and see if it works. thanks
Old 05-13-2009, 12:43 PM
pozesd99''s Avatar
did you replace the brakes? that would set the caliper farther out. they fit fine then after i did my brakes i was stumped why they didnt' fit lol.
Old 05-13-2009, 12:45 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Keep Grinding. The tolerance of space between rim and brakes were pretty close to begin with.
Old 05-25-2009, 10:39 AM
cbrrmike's Avatar
when i switched from the 10 bolt to the moser i had to re-grind the rear calipers as well.....i never figured out why and just chalked it up to the c-clip eliminators.....not sure it was the reason though.
Old 05-25-2009, 04:20 PM
SILVER SS 00's Avatar
i grinded mine but i am using spacers as well,i am running draglites
