Anyone put OEM C6 ZO6 wheels on their F-Body?
Clint you will most likely have to run a spacer or a billet hub adapter that keeps the same bolt pattern but steps out the mounting point 1.25" then it should fit well with the 345s in it but you still might have to clearance it for rubbing the inside.
Ive looked into it as well
are you talking about buying rims that were on a c6 and then putting them on your car? cause if soo the offsets are waaaaaaaay diff and would be sucked in on your car so bad they wont fit with out doing some fabrication which even if done would look like ****... or are you talking about buying the c6's aftermarket with the right offset? if you get the right offset youll be fine... my friend has c6 z06 wheels on his firehawk and he has like 19X12 or something like that with 315 30 19 michilin pilot sport ps2 which by the way are like 500 dollars a tire or something like that... ridiculous... im going to try and get some pics
