Ruff Racing 278
Old 05-19-2009, 07:20 AM
Vassago's Avatar
Default Ruff Racing 278
So I got a hell of a deal on a set of 19" RR 278s. They were 8.5 all the way around. I wanted the staggered 9.5 in the rear but for the price I took them. I read the sticky on the tire info but i called discount tire and they told me I could put 275s on all the way around with no rubbing. My car is not lowered but soon will be. And i want to add the big brake mod. So will 275s work on all 4 corners or should I go with something like a 255. I wouldnt mind keeping them all the same size for rotation purposes. But if two sizes make a big difference its not that big of deal either. Just a summer car!
Thanks
Old 05-19-2009, 07:47 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
You'll need 275/30/19s, which if you haven't priced them, are expensive. As for fitment, the SS and WS6/Firehawk all came with 275/40/17s from the factory which is the same width and height as the 275/30/19s, so fitment won't be an issue as long as the backspacing on the ruff's is correct.
Don't do the 255s, they are too narrow and won't look right.
Old 05-19-2009, 08:15 AM
Vassago's Avatar
Very nice. Thanks for the reply.
275s all the way around would look good. I looked up 275/30/19 on discount and found the Top 5 for under 250 each. kinda pricey but not to bad. I have only ran yokohamas before. What would you guys recommend out of these 4?
Michelin Pilot Sport A/S
Falken Azenis ST115
Yokohama S.drive
Goodyear Eagle GT
Mostly just daily driving. im going to order me sum slicks for my stock wheels for the track.
thanks
Old 05-19-2009, 09:10 PM
Vassago's Avatar
Bump!!
Old 05-20-2009, 09:10 PM
peterlawl84's Avatar
Are you sure you can put 275 on an 8.5 wheel? 8.5 is the width of the stock T/A wheels and I had 245s on them, but thought 255 would be the widest to go on them...
Old 05-20-2009, 10:15 PM
Restricted User
Blakbird24's Avatar
Note that we are talking about 8.5" wheels. You can put a 275 on there, i've done it...but I don't recommend it. That's a pretty damn high tire to wheel ratio. I mean i've run them up to 140 and run several sanctioned events with them, and had zero problems...but I still don't like it.
Old 05-21-2009, 11:16 AM
Roy@vqmotoring.com's Avatar
Great choice 278's. Awesome looking wheels.
Roy
ww.vqmotoring.com
(877)-877-9420 ext 22
Old 05-21-2009, 02:11 PM
Orangemagic's Avatar
Good choice of a wheel for sure
Old 05-21-2009, 02:24 PM
yonerhottlt1's Avatar
I have a set of ruff racing staggered 19's on my car that i bought from a friend and they are 8.5's up front and 9.5's in the rear. I run 245/35/19 up front and 275/30/19 out back and they look great and fit perfect. I personally wouldn't run anything larger than a 255 on a 8.5 inch wide rim. I dont think it would look that bad either
Old 05-21-2009, 03:33 PM
spy2520's Avatar
stock wheels are 8".
Old 05-23-2009, 06:09 AM
formerly mystic-t/a (changed 02/05/2013)
ThatGuySkye's Avatar
I'd say 275s on a 19x8.5 rim is way too wide... especially for such a short side wall...
Old 05-23-2009, 08:45 AM
White.Lightning's Avatar
18x8.5/18x9.5 Ruff Racing 278 wheels
255/40-18; 295/35-18 BFGoodrich KDW2 tires here
Old 06-13-2009, 11:27 AM
98BlkFormula's Avatar
where did you pick your wheels up from? i cant find any 18" only 19"
Old 06-13-2009, 04:25 PM
The same place everyone else on this site purchases them from. I got them a year ago
Old 06-13-2009, 08:09 PM
UNDER PRESSURE MOD
Check reply #7, that's where I got mine.
Old 06-13-2009, 08:27 PM
they dont have 18" only 19" i guess they dont make 18" anymore
