Nitto NT01 OR Toyo R888
Old 06-12-2009, 11:17 PM
98RedBird's Avatar
Default Nitto NT01 OR Toyo R888
I'm picking up a new set of tires for the car and am split between these two. I will be tracking the car every once in a while and driving it on the streets as well. Treadware I don't care about as I only drive the car maybe 1000 miles a year. Nitto's seem to run a little cheaper and are more easily accessible. I can't really find too many vendors that sell the Toyo's...
Old 06-13-2009, 12:40 AM
tavi_ws6's Avatar
i haven't tried either personally, but one of the guys at the track a couple weeks ago swore by the toyo's and his 911 seemed to be lapping pretty good
Old 06-13-2009, 12:42 AM
tavi_ws6's Avatar
^actually i think i may have saw your car tonight, did you drive by monicals in pekin with a red ws6?
Old 06-13-2009, 01:39 AM
98RedBird's Avatar
Nope, I worked tonight, I don't have a Red WS6 though.
Old 06-13-2009, 02:02 AM
tavi_ws6's Avatar
i meant with another car, you- red camaro, someone else -red trans am
Old 06-13-2009, 02:06 AM
hitmanws6's Avatar
ive seen the NT 05s work well. have you looked into those as well?
Old 06-13-2009, 02:17 AM
98RedBird's Avatar
Ah, gotcha man.
Old 06-13-2009, 02:18 AM
98RedBird's Avatar
Picked up the Nitto's tonight! They were $200 cheaper than the Toyo's. From what I understand they are essentially the same tire, so I went with the cheaper of the two.
Old 06-13-2009, 06:43 AM
EchoMirage's Avatar
by tracking do you mean road course or drag strip.
Old 06-13-2009, 01:50 PM
98RedBird's Avatar
Road course... The NT-01's are not a drag tire. It's an auto-x or road racing tire.
Old 06-13-2009, 05:15 PM
EchoMirage's Avatar
i know. i was making sure you knew the same
Old 06-13-2009, 05:54 PM
BobDoLe's Avatar
R888s are awesome. they aren't the cheapest, but after trying a few different tires (riken raptors, falken azenis rt-615, kumho victoracer v700) i think i've found my tire for this car.
i was having traction issues after putting in a 3600 stall torque converter and now i can finally get on the gas pedal without sending the tires up into smoke. the victoracer v700 gripped pretty decent, but would still spin if i got on it under 30mph. i had to heat the victoracers up to get any decent launch traction out of them - and even then, they quickly reminded me that they were road race tires and NOT drag radials.
the r888's make me think maybe i don't need drag radials (i don't plan on launching on spray as i'm on my stock 10bolt). i was reading a few things on the net here and there (mostly corvette guys) where everyone was saying the grip was phenomenal. one guy even said the r888 was better than a 555r drag radial. i thought that was an exaggeration, but after driving on the r888, i think thats pretty true if the 555r isn't heated up. i grip so good on these things, im in disbelief - i keep thinking somethings wrong with my car.
the NT01 was on my list of tires to try, so let us know what you think about them.
Old 06-13-2009, 07:31 PM
hitmanws6's Avatar
i have toyo ra1s for my fronts. they grip like hell
Old 06-14-2009, 12:59 PM
98RedBird's Avatar
Yeah, I did a lot of reading over on the import forums about the RA1's, R888's and the NT01's. They all are a very good tire but the guys who were turning in the faster lap times were on an NT01. Most of the guys had had the RA1's in the past and then switched to the NT01's because of the increased grip... But the cost of the added grip was a harsh ride on the Nitto's, which everyone noted. Oh well, I don't mind that as I won't be daily driving this thing.
Old 06-14-2009, 05:53 PM
EchoMirage's Avatar
within reason, what works best on an import doesnt always work best on an f-body. for example, the gold standard, the bar against which all other street tires are measured (as per rags like grassroots and the like say) are the falken 615s. i use them as track tires on my TA. while they work great for light little jap cars like miatas, under a real car with real power and weight, they simply get greasy and loose. theyre not bad, and im sure better then any other street tire, but comparing apples to apples on 2 cars that are apples and oranges, you see the differance.
if youre talking true r-comps, or a hybrid like the NT01, results can be more level across muscle cars and imports.
Old 06-14-2009, 06:01 PM
davidbakergli's Avatar
a friend of mine broke his c6 z06 half shaft launching with NT05's. He swears by that tire.
Old 06-14-2009, 07:06 PM
98RedBird's Avatar
I think it will be pretty apples to apples with what I found. About 95% of the cars that were reviewing the tire were 400+AWHP STI's and Evo's, a few were in the 600AWHP range. And from what I've seen the newer Evo's and even the 9's and 8's aren't exactly "light" cars (Something in the 3300lb range). Our F-cars are heavier but it's not something I would call substantial. Mine should be right around those numbers with the weight trimming that I've done. Those were the only imports that I found that actually had user reviews of them. But I think from a standpoint of what the tire can handle laterally it should be reasonably close between the two. A 600HP all wheel drive car will be pretty brutal on a set of tires regardless so they'll probably work alright for me. But we'll see.
Old 06-15-2009, 07:35 AM
EchoMirage's Avatar
well take a look at what you just said. all those cars were AWD. thats a HUGE differance between just having RWD. lets say the AWD has 400 whp. thats sort of like saying each tire only has to handle 100hp each (of course im not considering torque, which is the true measure of power). conversly, if you have 400 rwhp, each tire has to handle 200 hp. thats alot to handle at just the rear of the car. and im not even taking in the variable of the AWD being able to transfer grip from tire-to-tire, or at least front-to-back, with thier center diff.
Old 06-16-2009, 02:23 AM
98RedBird's Avatar
Lol, I'm well aware of what I just said and I don't disagree with your response, but you're missing my point. We're on different pages but that's alright. I'm sure the tires will do just fine for what I ask them to do.
Old 06-16-2009, 02:30 AM
Black_Z28's Avatar
Interesting coming from a person who was asking for advice in the first place.
Quick Reply: Nitto NT01 OR Toyo R888
