are my bfg drag radials done?
there is very little tread in the middle of the tire, but on the sides toward the sidewall there is still a lot of tread. I just wasn't sure if they are still good to drive on because I haven't had them on for long at all.
As far as pressure, take whatever you were running and maybe drop 3-5 psi off of it if it was wearing unevenly. From the pictures it looks like they were actually wearing about like they should. You will probably save yourself money in the long run if you get a seperate set of 2 wheels for DR's and run normal street tires on the street, especially if this is your DD.
