MT ET Steets 295/45/17 ??
Old 06-28-2009, 06:01 PM
02_ramair_ta's Avatar
Default MT ET Steets 295/45/17 ??
I am looking at getting a pair and slapping them on my 02. I am just wondering if anyone has had them before, and what they thought about them.. Thanks
Jason
Old 06-28-2009, 06:09 PM
From the Summit site, they say it fits a 9.5 wheel.. that is what the 02 speedlines are right?? I have never measured them
http://www.summitracing.com/parts/MTT-3745R/
Old 06-28-2009, 10:43 PM
STREET99's Avatar
I am thinking of getting a set of these for my 2000 Z28. That is a sick looking tire and I got some buddies with camaros and cobras that have MT's and say they are the best.
Old 06-28-2009, 10:55 PM
kilrbecars1's Avatar
I like them, There a good street and track tire. I also have had a set of bfg's there work well also. In fact I have a set now in my garage.
Just remember they don't have a lot of tread when you buy them new.
Also they dont like water!
Good luck, post pics when you get them on.
Old 06-29-2009, 12:46 AM
SS#1230's Avatar
these are the only DRs ive ever used and ive heard they are the best drag radial. the 315/35 17s are still spinning a bit even with a line-lock burnout, and will spin good with a really hard launch. ive gotta do a 3/4 throttle launch then get into it.
but i wont say they dont hook well....
that size tire would be sweet on your rim though....
Old 06-29-2009, 09:16 AM
ndfrsd6's Avatar
^^^ MIGHTY MOUSE is going 1.33 60ft with these tires ! so i think they will hook hard .....its all in your setup ....and a M6 will have problems on every drag radial ,you need a bias ply to go fast at the track ... street wise you should be fine . run them at 22psi on the street and you'll hook
Old 06-29-2009, 09:19 AM
ndfrsd6's Avatar
here you go theres video in here....that tire is the best thing out there for traction !
https://ls1tech.com/forums/drag-raci...tires-pic.html
Old 07-02-2009, 12:05 AM
Well got them mounted, they look GREAT, I will post pics tomorrow, or after the 4th. PERFECT tire size for these speed line wheels.
Old 07-02-2009, 12:10 AM
JScamaro's Avatar
Will these work for the rear while using the stock diameter 26" tire in the front?
Old 07-02-2009, 02:54 AM
GreenBlood's Avatar
they work fine, but ur car will sit with a raked stance since the rears will be almost 2 inches taller than ur fronts. ur speedo will also be off due to the tire size, so if u have traction control and ABS or at least abs, those dummy lights on the dash will pop up. i had these on my speedlines for a lil while, i loved how they filled the wheel well, but I think they looked absolutely horrible from the rear. they fit on a 9.5 easily, but they aren't wide at all. my 275/40 fronts were a lot wider. made my car look like it was FWD Thats the past though. I'm sitting on prostars now with a 275/50 M/T, and I love these mickeys.
Old 07-02-2009, 12:38 PM
DopdBrd's Avatar
The 295/45R17 MT's are actually only a little over an inch taller than a 275/40R17. The 295's are only 27.2 inches in diameter compared to the 25.8 or something like the 315/35. So I guess it is closer to 1.5". But they won't be nearly as tall as something like a 325/45R17 M&H. Believe me, I know.
Old 07-02-2009, 01:13 PM
GreenBlood's Avatar
I know they are only 27.2, but yes, stockers are 25.6 inches tall i believe. I've seen the M&Hs, real tall. A lot of websites list the mickey's as 28x11.5-17s. Regardless, the car will stand raked. They just weren't wide enough for my tastes, and I didn't feel like lowering the rear of my car to fix the rake. don't get me wrong, it looked cool, but I could tell my headlights weren't pointing as high as they were before. It got annoying
Old 07-02-2009, 02:59 PM
bluehawk2's Avatar
I have those tires as well and I really like them.........they are actually more tire that what I need right now, but I'v got a two step and a t-brake in the plans
I am going low 1.6 60's on any track surface right now
Old 07-03-2009, 12:39 AM
STREET99's Avatar
I am thinking about getting these for my 2000 Z28, but getting them in the 275 size. Would they have any problems fitting and would there only be problems with if I went with a 295+ tire size, just like what was stated above about racked up rear, speedo inaccurate,etc..?
I found these tires in 275 on the same site here but why is the tread pattern different?
http://www.summitracing.com/parts/MT...R/?image=large
Old 07-06-2009, 02:44 PM
bluehawk2's Avatar
I didn't have any problem with mine fitting, If you go to a 275 it will be the old tread design though
Old 07-09-2009, 10:13 PM
lower90xcab's Avatar
im thinking about ordering these to put on my 17x10s.....
Quick Reply: MT ET Steets 295/45/17 ??
