15x10 6.5" or 7.5" BS?? pics would help.
Old 08-28-2009, 05:46 PM
01SOMZ28's Avatar
Default 15x10 6.5" or 7.5" BS?? pics would help.
I'm wanting to get some 15x10 wheels but i want to know what b.s. to get. I've been told 6.5 and/or 7.5 backspace. I'd like to know some thoughts and maybe see some pics of each to help make my decision.
Old 08-28-2009, 06:00 PM
DopdBrd's Avatar
Your going to get mixed reviews. A 7.5" BS will fit on any F body and you can fit anything from a 26x11.50 to a 325/50R15 on it with minor work.
A 6.5" BS will work but on a Camaro you are limited to running only a 26" tall tire.
A 6.5" will work with just about any size on a Firebird/Trans Am with your fenders rolled and a little BFH'ing. You will have to hammer less with the 6.5" BS.
Old 08-28-2009, 06:06 PM
01SOMZ28's Avatar
Im limited to running a 26" slick anyways since my car is lowered. I've ran a 28" slick before and it rubbed bad when i was at WOT and the *** end squating down. But it was because my fenders are not rolled and thats where it was rubbing along with a little inside the wheel well... I do plan on rolling my fenders and i'd like to run a 325/50 someday but i just plan on running a 26x11.5 right now.
Old 08-28-2009, 06:08 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
It needs to be 7.5" or it will stick out.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 08-28-2009, 06:21 PM
01SOMZ28's Avatar
can someone post some pics with 6.5" and 7.5" backspace
Old 08-28-2009, 06:23 PM
NSSANE02's Avatar
Old 08-28-2009, 06:29 PM
DopdBrd's Avatar
I beg to differ. 15x10 Summit Star with 6.5" BS with a 26x11.50R15
Old 08-28-2009, 06:30 PM
NSSANE02's Avatar
7.5" BS lowered with a 275/60/15
And with the new 325/50/15's
Old 08-28-2009, 06:34 PM
01SOMZ28's Avatar
the pic of the 6.5 bs looks good to me, but damn i love the looks of those 325's
Old 08-28-2009, 07:04 PM
jmm98LS1's Avatar
15x10 7.5" backspace, 325/50/15, stock rear springs w/hose mod
Old 08-28-2009, 07:07 PM
NSSANE02's Avatar
Yeah that 6.5 doesn't look bad at all but if you put a 325 on it, it would look ridiculous.
Just imagine this sticking out another 1' on each side...
Old 08-28-2009, 07:12 PM
NSSANE02's Avatar
That thing looks f'in great! But I had to cut a coil and do the hose mod to sit that low... Wonder why yours is lower?
Old 08-28-2009, 09:21 PM
The picture might not make it look like it, but 6.5" DOES stick out 1" further than 7.5" I think the numbers are self explanatory on that. Here is mine on a 7.5" backspacing. You can tell it's in 1" further than the 6.5 and the 325 tucks pretty well on that wheel. On a 6.5 it would would not tuck under properly. There are alot of pics on here of convo pros with a 6.5 that show you how much they stick out in comparison. The looks of it is subject to difference of opinion of course.
__________________
Old 08-28-2009, 10:05 PM
DopdBrd's Avatar
Food for thought.
A 17x11 Torque Thrust II has a BS of 7.75". Now compare that to a 15x10 with a 6.5" BS and the TTII has .25" MORE backspacing than the 15x10. So essentially, the 15x10 will stick out 1/4" further than a Torque Thrust II.
The reason you run into more problems with a 15x10 and a 6.5" BS is because people run a taller tire on the 15 inch rim.
More than likely, people running a 17x11 with run a 315 tire which is 25.7 inches tall. Now try to stick a 28 inch tire that is 12 inches wide on that rim and it will rub just like a 15x10 with a 6.5" BS.
Stick with a 26" tall tire and a 15x10 with 6.5" BS will work just fine.
Old 08-29-2009, 03:41 AM
CamaroRick's Avatar
does both 6.5bs and 7.5bs require hammering in the inner fenders with a 26"x10?
Old 08-29-2009, 09:37 AM
DopdBrd's Avatar
A 6.5 will require less since it does not sit as close to the inside fender.
Old 08-29-2009, 11:42 AM
Camaro396's Avatar
I don't care what anyone says. 6.5" backspace looks hillbilly whether it's on a Camaro or Firebird, and no matter what tire is on it.
Heres my old setup. Even 7.5 backspace with a spacer looks Joe Dirt.
New setup. 15x10 7.5 Backspace NO SPACER with 325/50r/15s
Old 08-29-2009, 12:07 PM
Turnin20s's Avatar
^^^LOL @ Joe Dirt^^^
Your car looks sick man, as well as the others posted above. After my rear end swap I'm going to have to get a drag setup for fun, it just makes the car look like it means buisness LOL
Old 08-29-2009, 05:56 PM
Camaro396's Avatar
I never understand you. You're the only one I ever see on the 6.5 backspace team whenever there is an arguement against it. Can you just explain WHY? I mean 6.5 or 7.5 shouldn't even be a question. If dude is going to buy brand new wheels why would you suggest 6.5? So he is limited to tire choices? So everyone thinks he lives in a trailer park when they see his car cruising around? I don't get it. Come to the darkside. 7.5 is where it's at.
Old 08-29-2009, 06:07 PM
BADD SS's Avatar
15x 10 3.375" backspace. Its 4" narrowed per side so that equates to a 7.375" backspace for a stock rear. Those are 28x13.50-15's on it. On a 325 radial they tuck nicely.
Quick Reply: 15x10 6.5" or 7.5" BS?? pics would help.
