Wheel/Tire Chaos!!!
Wheel/Tire Chaos!!!
Im looking to change my tires and rims. Im sure there are alot of sets out there for the track. Im curious to know what setups work for you guys and girls? My main reason is because every time I hammer down at the track all I see is smoke and there goes the other guy........ VROOOOM ~~ ~~ Down the track. A NEW ONE!!! More than once buy stock f bodies.
I have a stock weight
2k1-Z28
A4
LS1
cloth interior
3:73 rear
Stock trans ratio
stock suspension
Stock, Stock, Stock!
The problem is that the rims and tires I have now weight a ton!!!!
18X9.5 Steel/Chrome plated Z06 wheels. And Michelin Raptor Z rated tires.
I want to lighten the wheels as much as possible but keep the muscle look. BUT MOST IMPORTANT I want to speed off the line without spinning. Im thinking about track bars too. Let me know what works for you. Any suggestions welcome. =)
You can shave a good amoutn depending on your driving skills. I know on my street tires I'll spin thru 3rd easy on the street & on my slicks I hook before I'm outta first gear. I have yet to get a pass on them though. I got a few more things to get done before I go for a new best.
A puffy slick on the highway is a unique feeling. Took a while to get used to & you cant corner hard on the skinny fronts either. I would slow down far more than on my stock wheels for corners.
Yea, The chaos is in the traction on the track. "Drag Strip" 1/8th mile.
The car has the stock 7.5 10bolt rear and a 373 gear. I would like to keep this a budget build for the street/strip. I also have a 100/shot. The car DOESN'T HOOK AT ALL w/o nitrous. It will spin even when I pedal It out past the 60/ft marker. I was hoping the gear would help my wholeshot time/60ft but it doesnt. This purchase for a stocl rear limited slip did not prove itself to be better than stock with a street radial. When I get my next shopping list started Im just looking for an inexpensive DRAG slick. Not to be street driven. Maybe this will cure my spinning trauma. =)
all you need is any rim with any "DRAG RADIAL" mickeys bfgs toyos and a nice burn out.
since your all stock no need to buy a wheel for the track only. do what most of us do and buy 255/50-16 mickeys for the original 16in wheels and toss them on when your gonna race.
