1/2 inch studs on front
Old 10-06-2009, 10:28 AM
getusumws6's Avatar
Default 1/2 inch studs on front
Does anyone know a part number for a press in front 1/2" wheel stud? ( for 00 camaro)
Old 10-06-2009, 06:57 PM
getusumws6's Avatar
do they even make 1/2 studs for the front ?
Old 03-16-2010, 09:02 PM
1999WHITEFRC's Avatar
I know this is a few month old thread,but Im in the same boat right now. I want to run 1/2 studs in the front because I have these fancy,pretty looking aluminum inserts and 12 point nuts I want to run. Looks like I have to find the right knurl size and drill them. I plan on using press in studs. It may be a little bit till I get to it but I will post up what I used when I do it,unless you have already let me know
Old 05-16-2013, 02:01 AM
ALTRDTA's Avatar
Bump. What's it take to get this done? Take off the front hub assembly and take it to a machine shop, or is it not even worth the upgrade? I really don't want to break a wheel off from coming down hard. Has anyone done it?
Old 02-19-2014, 02:14 PM
Cthulu's Avatar
Upgrading to a MWC 9 with the 1/2 studs, I would like my front and rear studs too match...sooo
BUMP
Old 02-22-2014, 12:12 PM
RobsZ28's Avatar
I put press-in 1/2-20 studs in the front hubs of my car to match the 1/2" studs in the QP 9". I bought Moroso #46185 3" studs. I did some research online before I did mine and found most people prefer .010-.020 smaller hole than the knurls. Moroso recommends the hole drilled to be .005-.010 smaller than the knurls. I drilled the holes out with a 9/16" bit then finished it off with 37/64" drill bit. 37/64 made it .016 smaller than the .594 knurls on the 46185 studs. Just have to make sure the drill is held straight and firm, I also drilled the holes in the brake rotors a little larger.
Old 02-22-2014, 12:16 PM
ss performance's Avatar
I think ARP makes some as well.
Old 02-22-2014, 03:54 PM
1981TA's Avatar
Wilwood uses 1/2 x 20 screw-in studs. I don't know the part number but it should be easy enough to find. You also might try asking your local parts store to let you look through their stud / lug nut cabinet behind the counter. I've had great luck there.
Quick Reply: 1/2 inch studs on front
