315/35R17 on AR TTM 17x10.5 - Will it Rub?
Old 10-17-2009, 09:42 AM
Poison's Avatar
Default 315/35R17 on AR TTM 17x10.5 - Will it Rub?
Hey guys,
I've read thru as many posts as I can on wheels for my car - thanks for all the information, but I'm still searching for one answer: I know that a 315 will go on the 10.5 Torq Thrust M Rear, but will it rub? Is there any modification that I need to do to make it work? I have a stock height SS convertible and want a wider tire than a 275/40 for the rear, but don't want to modify or bend anything. If a 315 won't work, how big can I go - a 285/40? Thanks in advance. Poison
Old 10-17-2009, 09:54 AM
Poison's Avatar
Sorry guys - I certainly meant 315/35s not 65s... my fingers were working too fast. sorry - couldn't edit the topic.
I fixed it for you . . . Xsta Z 28
Old 10-17-2009, 10:10 AM
nealws6's Avatar
i have nitto 315/35/17 on my 00 ws6, did not had to modify anything
Old 10-17-2009, 08:09 PM
LoudGM's Avatar
You don't have to modify as long as you don't lower it. Then you most likely have to roll the fenders.
Old 10-17-2009, 08:25 PM
99Bluz28's Avatar
Stock height no problem!
If you already have a adjustable PHB, then lowered should be no problem also.
Old 10-18-2009, 10:56 AM
69TA's Avatar
just get an adjustable phb or roll
the rear quarter lips with a fender roller.
i got one for rent if you don't want to buy the roller.
Old 10-18-2009, 11:01 AM
madmike9396's Avatar
i put those on my 17x11 zr1s on my 96 z and i had to roll the fender and remove the bump stops
Old 10-18-2009, 11:38 AM
Moderator
davered00ss's Avatar
Rear inner fender is wider in a Firebird than a Camaro.
Read the wheels stickey above. You will most likely need to remove the bump stop, BFH mod and possible roll the fenders, even @ stock height.
Old 10-18-2009, 12:57 PM
DopdBrd's Avatar
I was running 315/35R17 Nitto Drags with no problems on my TTM's. So was my buddy on his Camaro.
An adjustable PHB would be great if you don't have one. Help's center the rear and if you have to "clearance" anything it will be minimal if the rear is already centered.
Welcome to the club.
Old 10-18-2009, 01:36 PM
whytryz28's Avatar
Lowered 1.8" (probably more since the springs are settled)
Rolled lips
Stock Bump stop
Hammered inner fender well
Double adjustable PHB
Old 10-18-2009, 09:41 PM
Gordo78's Avatar
1.6 drop
Bmr adj phb
315/35 nitto 555's
TTII's though
Had to hammer front of the fenderwell, and roll the lips. Bumpstops are stock, only rubs on them when the springs are fully decompressed.
Old 10-19-2009, 05:54 PM
01SuperSport's Avatar
You should be fine with stock ride height. Lowering is when you'll have to start modifying
Old 10-19-2009, 07:54 PM
Datzneat's Avatar
Make sure you have an adj panhard and make sure your rear is centered. If so you'll be fine. I am running the same thing right now.
Quick Reply: 315/35R17 on AR TTM 17x10.5 - Will it Rub?
