Abs/TCS Inop
Old 10-31-2009, 09:31 PM
Egg1456's Avatar
Default Abs/TCS Inop
I just put some y2k corvette rims on my 95 firebird formula and when i reach 25 mph my abs and tcs turn off, i also had to grind the abs exciter ring a little to get new studs into the hub. Soo are the rims causing the problem?
Old 10-31-2009, 09:56 PM
sgm98ws6's Avatar
DO A SEARCH!!!! Just messing with you... looked on here a bit and im pretty sure that changing tire sizes can throw it off. with your stock wheels in back you went from 25.6 od to a 26.6 od with the new wheels. Maybe someone on here a little more experienced can go into depth with this. Could also be that one of the sensors is too close the the wheel / hub.
Old 11-01-2009, 09:20 AM
Egg1456's Avatar
you didnt notice your abs turn off when you put yours on?
Old 11-01-2009, 09:29 AM
'Trust''s Avatar
Tire sizes on your old wheel, and now on your new ones? You will throw the ABS sensors off if your rear tires are a different overall diameter than your fronts, most likely the case.
Old 11-02-2009, 04:56 PM
Egg1456's Avatar
anyone know where you can get a new abs exciter/reluctor ring from, apparently gm discontinued them
Old 11-02-2009, 05:05 PM
3Camaros's Avatar
I agree that if you are running different size front and rear this is something you will have to live with. The ring will be on axles in salvage yards. I have a bent axle with one but I am not sure I could get it off without destroying it. For probably $100 salvage part I would just replace the whole axle.
Old 11-02-2009, 05:56 PM
Egg1456's Avatar
yea im looking at some people parting theirs out
Old 11-05-2009, 09:35 PM
LiT1_up's Avatar
Originally Posted by 'Trust'
You will throw the ABS sensors off if your rear tires are a different overall diameter than your fronts.
We have a winner.
