18X10.5 z06 wheels 285/35/18 tires will it need a BFH mod?
1 Post
hey guys just got some 01 z06 wheels, the rears are 18X10.5 will a 285 tire in the rear fit? or will i need to bang in the inner part so that it fits? would a 295 possibly fit? and also will i need to have the fenders rolled? or do i need any wheel spacers? the car is dropped on vogtland springs about 1.5 inch drop. thanks guys
1 Post
if im not mistaking pointac firebirds/trans ams/ws6 quarter panals are fatter around the wheels so you can even fit a 315 without rolling your fenders with the right offset. but thanks for the response.
yeah that may be true, just not personally sure if so, how much exactly but just thought it would help.
and you didnt say it was only for camaros so i thought i would reply
good luck
good luck
1 Post
thanks for the response's guys, the rims are factory, i guess i will have to fit them on right now, they have some 295's on there but there a bit worn so it will be great to try em out.
yes, but what how far did you drop your ride height? I don't mean to hijack anyones thread but I'd also like to know this. I was thinking about getting stranos spring and koni package which should drop it 1 1\2". I am making about 380rwhp and 275s just don't cut it. I was looking at oes' wheel package with 19X10s rear and 18x9s up front. What I need to know is what is the widest tire I can fit without having to mess with the wells in the rear?
i have deep dish 18x10.5's c6 z06 wheels with 285s micheline pilot sports and my cars lowerd as-well they where fine untill i broke my tires in and started railing on corners they rubbed on the inside of my left rear wheel-well so i did the bfh mod and have had no rubbing and no need for fenderlip rolling. you should be good bro.
My vote is that if they are Corvette offset and your BMR PHB is adjustable, just run a 1/4 inch spacer and you'll be good with 285s or 295s. I ran 275s on Z06 rims on my SS for over a year (with stock PHB) and only had very light rubbing on one fenderwell. Between the spacer and getting your rear centered, you should have no issues. If all else fails, measure the BS and consult the sticky in this section.
