help! bogart d10s on street?
i am getting ready to order 15x4 and 15x10 bogart d10 wheels! anyone have problems running them on the street? also what is stronger prostars or bogart d10s? also feel free to post up some d10 pics! thanks aj
1 Post
They are the P2s I think, knows as "Bolted Bogarts" or "Street/Strip Bogarts" Call Steve at SJM or go to the website: http://www.sjmmanufacturing.com/
i have a set on my car.the front wheel cracked called rich bogart and he took care of it.you need 2 run a biase tire. steel belted tires are not good 4 them!
allso not 2 much air press! 35 max
A Prostar is probably less prone to breaking on the street than a D10. The front Prostars are about 2 lbs heavier than a comparable D10, the rears are about 5 lbs heavier (for a 15x10) IIRC. The Bogarts can be designed for Fbody brake calipers; Prostars suck deez nuts with respect to that.
im a huge fan of the bogart d10s! but like hawk said, get the street version... but, have you thought about billet specialties street lites?? they make the rears in fbody specific, and the fronts you have to shave alittle bit of the calipers... but you dont have to grind as much as you would with the prostars...
