Oem Y2k Wheels on 99 Camaro
Need some help here... I got a set of OEM y2k wheels. They are the ones with the 18x9.5s in the back with a 65mm offset (I think). What size of spacer would you suggest running with this? Also would 245/40/18s look funny on the back?
Thanks for the suggestions!
-G
-G
Reason A. they were cheaper but I decided on a bigger tire.
B. on your car, the wheels looked "tucked" as they do on mine so a 1 inch spacer should line the end of the tire up better with the fender.
Ya our cars look very similar from that kinda "3/4 angle". If you or I did the hub centric 1 inch spacer it would look more aggressive. Kinda like an 11" wide wheel. I was just seeing if anyone had first hand experience and pics of different wheel spacer sizes.
