HELP Any one with a reverse offset on a american racing torque thrust2 Details inside
Does anybody have a 17 X 11 torque thrust 2 with a 4.5 back spacing in a reverse offset?
I PMed you the link, i don't think summit is a sponsor here, i could be wrong. Do you mean negative offset? The ones i sent the link for are -38.00mm offset.
I'm actually ordering a set from summit with 5.5 back spacing for the narrowed rear end im ordering from MWC. I called summit, and the custom back spaced rims are special order, but they said i would have the rims within a week. Not bad for a custom order.....
i meant does an one have these rims in a reverse offset (reverse offset-means no step on the rim all lip) i order mine like that cuz at first said i could and a couple of week ago they came today but not with a reverse off set then i called them an guy said sorry they cant make them in that with the 17x11 with 4.5 backspacing just wondering if he was bullshiting me or what?
its cheaper then that i do believe u got to call them its says prices so cheap that cant put the on site...like i said i payed 540 shipped lug nut and stems on a custon backspacing
do you mean reverse barrel? when you order TT2's with anything less then 5'' backspacing the barrel is reversed they will look the same but the tire is recommended to be mounted differently.
You can order TT2's with a flat lip and no step just not in 17'' size.
