Making 335s fit on an F-body (pic heavy)
Old 05-22-2011, 08:57 PM
WS.666's Avatar
Default Making 335s fit on an F-body (pic heavy)
So...a few months ago, I found this guy in Texas that was selling his widened Black ZR1s. They started off as 17"x11" wheels and he had them widened to 13". I like being unique and I figured that since he had gotten them to fit on a T/A, I could do the same. Also, I already had Black ZR1s on my car, so I wasn't really changing the theme of my car.
275s vs 335s:
Inside of the wheel:
Wheel Spacer...I didn't want the wheel to stick ridiculously far, so I decided to have it tuck further in. I cut the studs off the spacer because I'm running 2.5" ARP Wheel Studs, and they go all the way through the spacer, and have enough threads for the entire lug to tighten onto.
Bump Stop (and some more) ground off...there was about a quarter inch worth of space, and was too close for my comfort.
After inspection to make sure that the inner fender wasn't part of the rear frame, I decided do some cutting. I cut about half an inch worth (the ridges made it thicker than the metal actually was).
Ahhh...lost more room now:
Some POR-15 to prevent rust...I'll be spraying some rubber undercoating on there when the paint dries.
Now for the good stuff...
What do y'all think?
PS: Yes, I know they're bald...they're getting replaced soon.
Old 05-22-2011, 09:02 PM
k0261886's Avatar
Love that you are doing all this to get them to fit, and doing the write-up. I have to be a little critical, please take it as constructive. They stick out too far. I think a spacer in the 1.75-2" range would look MUCH better
Old 05-22-2011, 09:08 PM
carlos8's Avatar
nice...............
Old 05-22-2011, 09:14 PM
chaman's Avatar
LS1Tech 10 Year
Originally Posted by carlos8
nice...............
No. Please lets be honest. Those stick too far.
Old 05-22-2011, 09:17 PM
WS.666's Avatar
The spacer is a 1.25"...1.75"-2" would make it stick out further.
You're right...they stick out a little too far for my liking too, and I may drop the spacer down to a 1", but I'm not going to get them in much more.
Old 05-22-2011, 09:36 PM
PERFECT Z28's Avatar
They are way too far out, you'll get more inner room with tubular LCA's so that you can run a smaller spacer.
Old 05-22-2011, 09:41 PM
whytryz28's Avatar
Yeeeeeeehawwwwwwwwwwww!!!!!!!!!!
Old 05-22-2011, 09:47 PM
lees02WS6's Avatar
LS1Tech 20 Year Member
Are the LCA's really the hold up at this point to tucking 335's?
Old 05-22-2011, 10:11 PM
I have 345/30 r19's on my camaro...
Old 05-22-2011, 10:45 PM
BADBOYZ28's Avatar
Look good but IMO also they do stick out a bit to far.
Old 05-22-2011, 10:46 PM
carlos64030's Avatar
Lies. I don't see any pixturz to back up your claim.
Old 05-22-2011, 10:49 PM
98mysticZ's Avatar
i ran 335/35/17 hoosier drag radials on the 17x11 wheel with no spacer
Old 05-22-2011, 10:50 PM
BLINGOLE's Avatar
i love em! if you could go 1/4 more in that would rock but if not oh well
Old 05-22-2011, 10:54 PM
BADBOYZ28's Avatar
So did I with no modification at all. But his are 17x13 so those two extra inches is why he had to do all that.
Old 05-22-2011, 11:03 PM
WS.666's Avatar
I'm strongly thinking about it...spacers are cheap. We'll see how it goes with this set up.
Old 05-23-2011, 12:20 AM
SHovV's Avatar
i think they stick out too far. but i dont think tubular lca's only will get you the clearance you need. neither will offset lca's or smaller spacers. if you want em flush or tucked in barely, you'll have to minitub. ask me how i know.
18x12's
and im sure its common knowledge that 335's fit fine on 17x11's with a little bfh-ing. good luck on the project man. keep us updated
Old 05-23-2011, 04:55 AM
Posi's Avatar
Agreed. Too far out and also too much fender gap. These cars look great pushing the limits of the fenderwell. I do not understand why so many posters here want to make their cars look bad by exceeding the limits of the vehicle. Mini tub or buy a vette if you want a fatter rear.
Old 05-23-2011, 05:23 AM
5w20's Avatar
hellaflush
Old 05-23-2011, 07:35 AM
ramairetransam's Avatar
LS1Tech 10 Year
they stick out too much , bring them in 1/2 and see how it looks .
Old 05-23-2011, 07:48 AM
lees02WS6's Avatar
The rear fender gap is very large. What's going on there? Even a stock spring shouldn't produce that much.
Quick Reply: Making 335s fit on an F-body (pic heavy)
