Anyone ever run 305s on a 9.5" wide wheel?
Old 07-27-2011, 05:13 PM
V68Sweep's Avatar
Default Anyone ever run 305s on a 9.5" wide wheel?
I am trying to purchase 305/30/18s from a member on here and my current rim size is 9.5" in width. I've been told this is pushing it, so I don't want to spend the money and find they won't mount.
Has anyone ever had this particular fitment? Everything work out ok?
BTW, car is just a DD, and will not be track driven.
V68Sweep is offline
Old 07-27-2011, 09:13 PM
'00_Z's Avatar
To quote the sticky;
"9.5" ..... +38 to +56 mm .... 255, 265, 275, 285"
I wouldn't try it.
'00_Z is offline
Old 07-27-2011, 09:52 PM
1BAD02WS6's Avatar
It will mount just fine. It's not unsafe, but will not wear correctly.
1BAD02WS6 is offline
Old 07-27-2011, 10:54 PM
9WhiteCamaro9's Avatar
Most I'd go would be 285. 305 is way out of the range for me. But that's just me.
9WhiteCamaro9 is offline
Old 07-27-2011, 11:09 PM
Xsta Z 28's Avatar
No way . . . 285/35 tops . . .
Xsta Z 28 is offline
Old 07-28-2011, 07:33 AM
tbird31's Avatar
agreed.
don't listen to this guy.
tbird31 is offline
Old 07-28-2011, 07:58 AM
1BAD02WS6's Avatar
Ya don't listen to me. I have only been in the tire business for 10 years.
He asked if running that size tire would work out ok? The answer is yes it will work but it will not wear correctly on that size wheel.
Old 07-28-2011, 08:11 AM
allout06's Avatar
truck tire? yes, car tire? no.... youll get it to mount but you wont be putting 305 worth of rubber to the ground. even though i forced a 275/35/18 on a 8.5" wheel on the front of mine :-/
allout06 is offline
Old 07-28-2011, 10:48 AM
V68Sweep's Avatar
How will it not wear correctly?
V68Sweep is offline
Old 07-28-2011, 11:18 AM
DopeFedZ's Avatar
Go to tire rack and look up that size tire and look at the specs link. Each tire they had mininum rim width was 10.5". So can you get the tire to mount probably so. Should you though? Probably not.
DopeFedZ is offline
Old 07-28-2011, 11:22 AM
V68Sweep's Avatar
Well that's my question, why shouldn't I if it will fit? Sorry if that sounds dumb, but I'm honestly not sure why and am trying to find out!
V68Sweep is offline
Old 07-28-2011, 11:23 AM
allout06's Avatar
squeezing a wide tire on a narrow rim causes the out side of the tire to bulge... causing the edges of the tread face to not touch the ground...
allout06 is offline
Old 07-28-2011, 11:54 AM
1BAD02WS6's Avatar
this^ its the balloon effect. The center of the tire will wear faster. You could counter act that by running a lower pressure but thats just dumb and unsafe
Old 07-28-2011, 12:28 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
305 is overstreched for a 9.5.
rudytirerack is offline
Old 07-28-2011, 01:39 PM
V68Sweep's Avatar
Dang, thanks for your reply though! I always appreciate a sponsor's help!
For future reference, is a 295 ok with a 9.5" wheel?
V68Sweep is offline
Old 07-28-2011, 01:54 PM
BlkBird2000's Avatar
You don't need a sponsors feedback to get the correct answer. It's pretty simple. A 9.5" wheel should have at largest a 285. If you want a bigger tire get wider wheels!
BlkBird2000 is offline
Old 07-28-2011, 03:55 PM
1BAD02WS6's Avatar
I run a 295/35/18 firestone and the fit is just about perfect. Keep in mind that some manufactures measure a little differently, my 285/35 Michelin actually appeared to have more bulge to it.
I say all this just to give you my experience. If you were a customer that came to my shop I would suggest no larger than a 285/35.
Old 07-28-2011, 04:26 PM
^2x on different manufacturers having different actual size than what is listed on the tire.
Old 07-28-2011, 04:52 PM
lifeisgood's Avatar
like everyone says, it will fit and you can run it. but its just not a good idea.
listen to the sponsor.
lifeisgood is offline
Old 07-28-2011, 05:10 PM
LSjim's Avatar
my car has 295s on it on so oem ss rims
LSjim is offline
Quick Reply: Anyone ever run 305s on a 9.5" wide wheel?
