Need wheels polished
Does anyone know of a aluminum wheel polisher in the DFW area who polishes aluminum wheels? I have a set of Boyd Coddingtons and they need a freshen up. The tires will be off of the wheels to aide in the ultimate shine.
Anyone from the DFW are all the way up to Oklahoma City, I have a truck and will travel to drop the wheels off.
Thanks!
Chad
Thanks!
Chad
Wet the ball and wring it out/sling out water. Either lightly swirl the polish onto the tip/edges or small dime size drops. Dab the power ball on the areas of the wheel you want to polish to force it into the foam. Start the drill slow for a few seconds before going to high speed.
That should result in no slinging unless you don't get enough water from the rinse out of it.
Hand jobs suck, they never have the brand new shine like a proffesional with a buffer on a stand. They are the Fury wheels 18x10 - 42mm offset, 18x9 - 38mm offset.
There use to be a guy in Oklahoma City that did it but he closed. I am thinking about sending them back to Boyds but I bet that aint cheap.
A pro makes it look like a mirror again and then you aply Zooks to make it last.
So, does anyone have a shop locally? Thanks!
Chad
Chad
