just got 18 19 c6 wheels rear tire size help
Front ones bolt right up rear rims have no tires my friend is selling 305 /35/ 19 will does tire fit and what size adaptor do i get with does wheels thank u
its not ideal...but im running 305/30's on my oem c6z wheels...if your running the regular c6 wheels...(19x10) i think it should work fine...your getting them at a great price right?
i would bolt up the rears and see what kind of spacer you need, but iirc you will probably need around a 1in spacer (oe wheels...i think)
plenty of threads with this info...
If its the OEM C6 Wheel i just ordered mine in the same size. Needs a 1.25 spacer for the rear, fronts fit correctly. If its an OE Replica wheel I believe it bolts straight on without spacers.
Douchebag On The Tree
LS1Tech Platinum Sponsor
our 19" wheels will need an adapter to fit. the size of the adapter is all depending upon your individual vehicle.
__________________
Nelson W. OE Wheels
Customer Service Rep. & Sales
nelson@oewheels.net
Give us a call for fast service!
(866) 273 - 3651
Check out our wheels!
Nelson W. OE Wheels
nelson@oewheels.net
(866) 273 - 3651
