Staggered Wheels
Old 09-30-2011, 01:22 PM
FTBNY's Avatar
Default Staggered Wheels
Hello,
I have a set of 1999 Vette wheels (17x8.5 and 18x9.5) that are going on a Formula. Since it came with the same size tires in all four corners, should I go with 285/30-18 and 245/40-17 instead of the 275/40-18 and 245/45/-17 (that came stock on the Vette wheels) to keep the same diameter? If I don't will it cause ABS issues? Any handling differences?
Thanks for any help,
Bill
Old 09-30-2011, 02:02 PM
99Bluz28's Avatar
Originally Posted by FTBNY
Hello,
Bill
See, that's the problem with running a staggered wheel diameter with a ABS car. Either you keep the ABS happy, or you eyes happy you can't have both.
ABS Happy:
Keep the tire height the same front and rear, then it'll look like crap because the rear tires have shorter sidewalls.
EYEs Happy:
I'll look great, but the 1" difference in tire height is going to cause some ABS confusion, bad.
IMO, that's why I'll always stick with the same wheel diameter wheels front and rear.
Old 09-30-2011, 02:15 PM
poltergeist 02's Avatar
LS1Tech 10 Year
i would go with 245/45/17 front and 285/35/18 rear. this should put both diameters at 25.6" give or take .2".
Old 10-15-2011, 06:15 PM
FTBNY's Avatar
Thanks for the input, I'll check those out.
Quick Reply: Staggered Wheels
