Tallest tire
Old 11-02-2011, 04:40 PM
rod214's Avatar
Default Tallest tire
I have 18x9 and 18x10 rims . What is the tallest tire we can use for these ? I was looking at the BF Goodrich G-Force 275/35-18's for the fronts and295/35-18's for the rears . The 275's are only 25.5 inches and the 295's are 26 inches . Will that look to small in the wheel well ?
Old 11-02-2011, 07:10 PM
DWake's Avatar
I have 275/35/18 in the back and they look small, and I'm lowered on eibach pros. Anyone else able to chime in? I'm really wondering if 275/40 will fit with no problems, says its just another inch taller.
Old 11-02-2011, 07:52 PM
PACKERSz28Camaro's Avatar
Fit a 295/40/18 on my 18x10.5's on the rear with minimal BFH.
Old 11-02-2011, 08:01 PM
DWake's Avatar
Yeah, I guess worst case I'll just have to break out the mallet if it rubs
Old 11-02-2011, 08:22 PM
rod214's Avatar
Default 295/40/18
How tall ?
Old 11-02-2011, 11:54 PM
fern's Z's Avatar
i have 315-30-18 on mine and they work pretty good and it gives the optical illusion as if it was a bigger tire
Old 11-03-2011, 08:45 AM
Captain Double Post
BOBS99SS's Avatar
just know going to tall will throw your abs into wack mode, i dont know how it works with 18s but i know when i went with a 28 inch tall tire on my drag setup it set my abs lights off, it might not be an issue to you but then it might be, i just plan to delete my abs
Old 11-19-2011, 04:38 PM
rod214's Avatar
Default Weld RTS's and Nitto's with pictures.
Went with Nitto NT 555 R 305/35ZR-18 on the rears which are 26.4'' tall .
Fronts are Nitto NT 555 275/35ZR-18 .
I think they fit the wheel well a little better . Still want to install
lowering springs .
Old 07-12-2013, 04:02 PM
Rise of the Phoenix's Avatar
^^^ I want a set of those so bad for my Pewter WS6. What was the total cost (wheels and tires) for this combo?
Old 07-13-2013, 12:16 AM
1999BlueTA's Avatar
Sick T/A!!!
Quick Reply: Tallest tire
