15x4 and 15x10 Wheels That Require No Grinding
with LT1 brakes my centerline warriors slip right on no grinding whatsoever. I've heard the summit wheels will fit LT1 brakes as well also the race star wheels are supposed to fit.
No one says you have to answer a posted question.
If it bothers you so much, just skip over it.
To the op.
Bogarts fit w/o grinding, both front and rear.
Billet Specialties either a spacer for the front, or grinding.
The Welds will "sometimes" require just a slight bit of grinding up front.
But most folk's say they fit w/o any issue.
Only for the rear.
I'm just saying, there's a lot of morons that can't seem to realize their same question is posted two topics down from the "create new thread" button.
Did you just quote me and then post the exact same information I did?
Take it easy killer.
To the op.
To the op.
It is the correct answer, is it not? Ask the same question to two different people, if you get the same EXACT answer from both, it gives it a bit more credibility.
I just did a search on people bitching about people not using the search and I found 1,436,432 posts on the subject! I also found 652,785 complaints of people bitching for bringing up old threads!
