American Torque Thrust 17x9.5
Old 05-25-2012, 03:58 PM
Transamtx's Avatar
Default American Torque Thrust 17x9.5
Can I run 315 on rear without modifications of rear wheel? Which tire can I run without it rubbing? Thank you
Going for looks more than anything else not a daily driver only bolt ons nothing special
Old 05-25-2012, 04:03 PM
99zee's Avatar
That wheel is too small for a 315. Yes, it can and has been done but not recommended. Wheel offset and suspension are key factors in fitting the 315's. Stock height or lowered?
Old 05-25-2012, 04:36 PM
Transamtx's Avatar
Height is stock
Old 05-25-2012, 05:53 PM
9WhiteCamaro9's Avatar
Stock height or lowered, I still wouldn't put that big of a tire on that small of a wheel. The biggest tire I'd put on a 9.5 would be 285/40.
Old 05-25-2012, 07:24 PM
Transamtx's Avatar
Thats terrible I just wanted it to look real nice....with some type of nittos back there i have 275 in the front
Old 05-25-2012, 08:28 PM
blackls1ta00's Avatar
if you saw the tire sticky then you know you shouldnt try anything bigger than a 295,why chance it?
Old 05-25-2012, 10:56 PM
Transamtx's Avatar
Cause i am a cheap *** and wanted the 315 rear look thats why.....didn't care about whole tire performing....anyhow thank you guys for your time it's awesome to be able to ask questions and get answers
Old 05-26-2012, 09:17 AM
99zee's Avatar
We all want to get away with as "inexpensive" as possible. Cheap=dangerous. There are only so many corners you can cut. A failure of the tire, wheel, fender, etc is not worth the price.
At stock height you can get an 11" wheel with a 50mm offset and run a 315 without any other mods to the rear.*
*usually every car is a little different
Old 05-26-2012, 10:42 PM
Transamtx's Avatar
K Ill get on craigslist theres a guy selling torque thrust like mine but 17x 11 rears
Old 05-28-2012, 05:43 AM
Mr.z/28's Avatar
Try out a 295/35/17.
I am as soon as my 285/40s give out.
