275/35/18 front and 295/35/18 rear?
Old 08-20-2013, 11:27 AM
TImmy_Jones's Avatar
Default 275/35/18 front and 295/35/18 rear?
Has anyone run this combo? Any issues throwing an ABS light or anything?
Thanks guys.
Old 08-20-2013, 11:33 AM
LS1TA_956's Avatar
It won't since there the same height
Old 08-20-2013, 11:34 AM
LS1TA_956's Avatar
275=width 35=height 18=rim size
Old 08-20-2013, 01:17 PM
SSCamaro99_3's Avatar
The middle number is the sidewall height as a percantage of width. Therefore, they are not the same height. However, I doubt the difference will be enough to updet the ABS sensor.
Old 08-20-2013, 11:05 PM
I think they are about an inch different. Still not enough to set them off?
Old 08-21-2013, 03:22 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
They are not the same height. That would be right about at the boarder of causing problems. I probably wouldn't chance it myself.
Old 08-21-2013, 05:45 PM
DonnieDarko's Avatar
I have been running this combo for about a year. I have nitto nt05 tires. There is exactly 1/2 inch difference on the height. 25.6 inches in the front and 26.1 inches in the rear. No abs issues at all . Rides great!
Old 08-21-2013, 07:48 PM
bulletz28's Avatar
I run this combo for about 10 years now with no issue...
Old 08-21-2013, 07:55 PM
Sommer86's Avatar
I'm running a 275 front and 285 rear. Never an issue.
Old 08-23-2013, 09:14 AM
Qcon's Avatar
I've got the 275/295 combo and the only issue is my speedo is 1-2mph slow at 70mph. So when the speedo reads 70, my GPS says I'm going 71-72.
Old 08-23-2013, 02:17 PM
Nice, thanks. So you have 295/35 and 275/35?
Old 08-23-2013, 06:50 PM
Revcore66's Avatar
The difference in width between the 275 and 295 is 20 mm. The sidewall height is 35% of the tire width in this case. So .35 x 20 mm= 7 mm, which is how much taller the sidewall is on the 295's. I've been running this combo for 3 years with no issues.
Old 08-23-2013, 09:04 PM
DemonicZ's Avatar
275/35/18- overall diameter 25.58 inches
295/35/18- overall diameter 26.13 inches
275/35/18- sidewall height-3.79 inches
295/35/18- sidewall height-4.06 inches
275/35/18 rpms-813.18
295/35/18 rpms-796.02
275/35/18 actual speed-62.14 mph
295/35/18 actual speed-63.48 mph
Diameter difference 295/35/18 +2.15%
I don't think the ABS goes off until you run a 28" tall tire like a 295/50/16
Old 09-05-2013, 03:43 AM
Raptor_WS6's Avatar
im running 285/35/18 (toyo t1 sport) and 335/30/18 (toyo proxes ra1) with no issues
Quick Reply: 275/35/18 front and 295/35/18 rear?
