Largest brakes that fit under ten spokes
Basic rule of thumb for aluminum wheels is the rotor diameter needs to be 4 inches smaller that the wheel diameter.
17 inch wheel 13 inch rotor
16 inch wheel 12 inch rotor
There might be wheels that this does not work with but I have never had a problem using this rule.
Good luck
Craig
Good luck
Craig
Both C5 and C6 front calipers are pressure-cast (instead of gravity-cast) and have extra stiffening ribs, so they are stronger and stiffer.
C6 calipers have extra material over C5 calipers, and are reported to be roughly 10% stiffer than C5 calipers.
Also, the pistons are a touch smaller on both C5 and C6 calipers (40.5mm versus 43mm), which helps with feel and modulation.
Super Hulk Smash
All of that translates to better thermal properties on a road course. On the street, there is almost no difference in stopping power. Then again, the CTS-V just handles more heat even better, but may not produce better stopping distances either (until you get into the triple digits where heat is a problem even on one stop).
Tires and pad compound still make the most difference.
There's a guy on the internet that fit the 4 piston cts-v brakes and a 14" rotor on his 17" wheel. Grinder on his calipers a little bit, used a spacer and longer wheel studs and they fit perfect.
Nate....you can get the V's to work WITH some work as mentioned above....you're handy enough to pull it off. If you're not going to pony up for the 18s, I probably wouldn't do it if you're looking for plug'n'play. C5 costs (iirc) are in the same ballpark as strategically shopped V package.
You can only fit the c5/c6 brakes under 10 spokes. Ive tried fitting 10 spokes under my cts-v brakes and they wont fit. my SS/ZR1 wheels do fit. The issue with the 10 spokes is that inside the wheel barrel closest to the spokes, it starts to shrink and wont allow you to run them. Unless you run a 1" spacer. Ive got a 15mm hub centric spacer on my wheels and they sit flush with the fender.
If your just wanting better performance, a good blank 98-02 rotor, carbontech 1521 pads and braided lines has worked so well for me that upgrading to something like a v front brake set up would be purely for cosmetic purposes. You should not have a problem though swapping to something like a c6 z51 front rotor/caliper which is 13.4". No reason at all to upgrade the rears, they are too much for the car as is.
