TT2 hub hits brake caliber help
TT2 hub hits brake caliber just ever so slightly but enough to scratch and scrap it about 1/8 there 17x9.5 Also I used the stock lug nuts just temporary could that mess things up. The wheel studs only go in to the lugs
Half way but to snug the wheel tight.
You guys think it's the stock lugs they should fit
That is the correct backspacing but maybe the offset is incorrect.
What brakes are you running?
I've ran a few sets of TT2's and never had that issue.
Do you have any pictures?
Back spacing is the same thing as offset just in different terms and how it's measured. A wheel with x amount of backspacing will always have the same offset as any other wheel the same width with the same backspacing. So you can count that out. If they're the right backspacing they're the right offset.
So after doing some online comparing of stock calipers and c5. I clearly a have c5 set up on my car.
So now can I run a 1/4 inch spacer and longer wheel studs cause that would slove the rubbing what brand would you recommend. Also is The stud install a diy job or would I have to take it some where.
Thanks for the help.
Douchebag On The Tree
I have NovusTech spacers on my DD and they are a quality product at some of the best prices I found. Whoever you go with, just make sure you get hub-centric, wheel-centric, or both. Cheap ebay spacers are lug-centric and that's when you end up with weird vibrations.
LS1Tech Platinum Sponsor
You should be able run a small spacer to get more clearance. It is very important to make sure you have enough thread engagement on the stud. H&R spacers are top quality.
