Words can't express how mad I am right now! Fikse needed
Last quotes I received where $250 a barrel and $450 a center. Are you sure the barrel is clear coated? On mine only the centers were. If you can strip the clear off the center without messing with the finish underneath then it can probably be clear coated again.
In my case the dumbass wheel shop gouged the center so I ended up getting them powdercoated.
Moderator
I had the Fikses on my 93 refinished. If you get one done depending on the finish they won't be able to replicate it to match the others. Mine were the technipolish, once they strip the clear and re-polished the metal they weren't going to be able to match the technipolish on the other wheels. So I had to have the entire set done.
Just a suggestion, call Fikse. I sent them an email a week ago about refinishing and havn't heard back. I hope that I can just pull the wheels apart, polish the barrels and have the centers stripped and new clear sprayed. I don't know where I could get the centers polished again other then Fikse.
