new ccw 505as stock 10 bolt
Going to pull the trigger and order some ccw 505as for my ws6 car has factory 10bolt I want to run 18x9s up front and 18x11 out back. Can I put the rears on without doing any mods to the car I dont want to roll the fenders or anything is it possible to get a 11 in wide rim on without doing anything to the car?
I ran the CCW 505a's (19x10 and 20x11) on my WS6 with a stock 10 bolt and didn't have to do anything other than hammer some on the inner front part of the rear fenders, which wasn't a big deal at all. I didn't have to roll the fenders at all, but my car was not lowered. If I were you, I'd go with 11" wide in the rear.
Ok cool thanks man my car isnt lowered either and I dont want to lower it I may need to get 19s to fill the gap a little more did u have to run spacers or anyrhing? And should I get 19x10s up front or 19x9s? Did it drive well with 19x10s up front?
im running 19x11s and im slammed, no problems. i rolled the fenders cuz i plan to run wider tires next year but they have been unrolled for 4 years with 305/30/19s with no problems. i bought mine off a guy that have them on a 02 firehawk and he had no modifications done to his either. depending on what tire you run you should be in the same boat since you are gonna be on 18s and not 19
thanks man, ive had 3 different setups on it to get it where it is now but it currently has qa1 adjustable coilovers and hotchkis springs in the front and qa1 shocks and prokit springs in the rear.
i didnt have to roll them but like i said i wanna try and run 325s next year so i did that for future real-estate lol mine are 19x10 19x11 and tires are 275/30 and 305/30. you would probably run a 35 series tire on 18s i dont know with out looking up tire specs.. most online tire places have tire calculators to figure out what sizes you need
I have 17x 10.5 Fikse with a 315 tire. Car has Strano spring, Koni shocks, MWC stock offset rear end. I had the set up on for a week, taking some corners at speed with no issue. Second time backing out of the driveway which has quite a dip. Sliced the sidewall so badly on a brand new tire that I had to replace it.
Now I know that the camaro has less fender width then the firebirds but it sure was an expensive lesson.
