Does anyone make a good 16X8?
I'm having trouble finding any aftermarket wheels in the original wheel size for my car (00 Z/28) I hate the snowflake wheels, but I don't want to put taller wider wheels on either. Any other options out there?
LS1Tech Administrator
Received 1,492 Likes
How about the stock '97-'99 style 16" wheel? I agree about the snowflakes looking awful, I immediately removed them from my '02 Z28 for the same reason. But I always felt the '97-'99 5-spoke 16x8 was a great looking wheel, and I would have kept them on my '98 except for the fact that I wanted a 17x9 size. If I specifically wanted to stay with a 16x8, those wheels would be my top choice.
17X9's I could live with. I just don't want to go any bigger than that. Everything I'm finding in a 17 though is a 9.5 wide. I just feel that that's getting too wide and heavy.
The reason you see all the reproductions in a 17x9.5" size is because this was standard for the later C4 Corvettes and, with the typical 56mm offset, they also fit 4th gen F-bodies just as well. It's more cost effective than also making a 17x9/50mm offset version and most people don't mind the extra width.
Having said that, several years back you could still find reproduction SS/ZR1 style wheels in a 17x9/50mm offset same as the originals, but I don't know if anyone is still making those new at this point. Used is also an option.
I'm not sure what the weight difference is between 17x9 and 17x9.5, but I can't imagine it's anything too significant.
As for tire sizing, most people use 275/40/17 on the 17x9.5, same as the factory did on the 9" wide version. However, the factory used a 285/40/17 tire on the 9.5" wide versions that came on the late C4 Corvettes, so that size is also an option but would increase weight even further. FWIW, you can fit the 285/40 on a 17x9 wheel too without any issues, but again this bigger tire adds more weight so I guess that's probably not the way you'd want to go.
Some people put 245/45/17 tires on a 9" or 9.5" wide wheel as well, it's the same overall diameter as stock 275/40s but a narrower width. Personally I think this looks too stretched and I don't care for it at all, but that size tire probably weighs a little bit less if that is your goal.
The main weigh difference I was concerned about wasn't going from a 17X9 to a 17x9.5. It was going from a 16x8 to a 17x9.5. My other concern was if there were any tire options for a 9.5 wide wheel. Mostly I'm concerned by up sizing if I'm going to hurt my acceleration and fuel economy?
But there are aftermarket 17x9 wheels as well, besides just older reproductions of factory wheels. Specifically I am thinking of the American Racing Torq Thrust M (more commonly referred to as "TTMs"). These are available in a 17x9 if you are really worried about that extra 1/2".
Again, a 17x9.5 can use the same 275/40s that would be typical for the 17x9 as well, so there would be no increase at all in tire weight beyond the 17x9 tire options. Myself as well as countless others have used this size on a 17x9.5 without any issues or concerns at all. But if you wanted more width, you could certainly use a 285/40 on a 17x9.5 as well.
You're overthinking things.
16" wheels/tires are basically outdated and obsolete (like 14" and soon 15" will be). Moving to a 17x9" or 17x9.5" with a 274/40r17 will give you tons more tire options for good prices and won't gain any weight you will notice.
For example I used to have 15x7" fronts and 15x8" rears on my car and replacing them with 17x9.5" on all 4 corners did absolutely no harm to my track times or fuel mileage averages. But the tires are incredibly better and were similar in price as the junk still offered in 15" sizes.
Learning about offsets has been interesting as well. I thought it would have been as simple as going in and buying the set of torque thrusts that I wanted in a 16x8 and that would have been it. Things are never that simple though.
I have the AFS reproduction 16x8s in the SS convertible/ZR1 style 5 spokes on the car as we speak, but I am CERTAIN that they discontinued this wheel LONG LONG ago.
As far as tire availability goes; there are almost NO decent 16" tire options left for these cars, and sadly, even the 17" options will probably be going away very soon, given the market's predilection for blingy, BIG, 'donky', ghetto-G hoops in 20"++ diameters.
14" tires are also still available, I have a daily driver that uses them. Yes, again, options are limited but they aren't hard to find when needed.
In terms of a 4th gen F-body, I agree 100%.
Just curious myself so I took a gander at just one website and it came up with 688 different style wheels in the 16 inch. Obsolete my @$$! Look bud, a couple clicks of the keyboard and the tap of the enter button should put you on the path to your chosen desire! Happy Hot Roddin' !!
What was the site? Everything that I have found in a 16 doesn't have a high enough offset to fit my camaro. Also I have had trouble finding a good tire for a 16 inch wheel in the correct size that the car came with.
