measure a bent aftermarket wheel...
Old 05-19-2016, 08:14 AM
rajbcpa's Avatar
Default measure a bent aftermarket wheel...
...got a bad whobble rr.... if it is a bent wheel, how do I determine the offset and width?
I'm carrying 315 tires all around but the front wheels are 10" wide and rears are 11" wide, I think...
...anyway, I'm certain the front/rear wheels have different offset...
Old 05-19-2016, 08:41 AM
rajbcpa's Avatar
car is 99 f-body Camaro with ZR1 style wheels.
can these be fixed or do I need to find a replacement?
Old 05-19-2016, 08:50 AM
Skraight's Avatar
It should be stamped on the inside of the wheel, will say 17hx9j et-45 or something similar.
Old 05-19-2016, 09:44 AM
rajbcpa's Avatar
...think I should repair or replace...???
Old 05-19-2016, 11:09 AM
IDriveChevy's Avatar
I would put it on a tire balancing machine and spin it and see if its actually bent or not, and then go from there.
Old 05-19-2016, 06:09 PM
rajbcpa's Avatar
....what else could cause a wobble? ...bent axle maybe?
Old 05-19-2016, 07:31 PM
JD_AMG's Avatar
Which zr1 style? C4 ZR1 or C6 ZR1?
Old 05-20-2016, 05:39 AM
rajbcpa's Avatar
....like the Bird in your pic - JD...
Old 05-20-2016, 08:02 AM
Skraight's Avatar
Take it to a tire shop with a good balancing machine like stated earlier. They can throw it on and tell you right away usually.
For as cheap as replica wheels are, I would probably just buy a new one over trying to fix it.
Quick Reply: measure a bent aftermarket wheel...
