Can i fit a 15x10 with sportline springs???
Old 11-16-2004, 04:59 PM
BTLFEDSS's Avatar
Default Can i fit a 15x10 with sportline springs???
My SS has Eibach Sportline Springs i am wondering if a Weld 15x10 will fit or if i will have to run 15x8 instead just ordered some skinnies now i just need the back.Believe it is a bout 1.5" drop in the rear.
Thnax BTLFEDSS
Old 11-22-2004, 11:28 AM
Derek98z's Avatar
It should fit. I run the pro-kit and 15x10
My best friend runs the sportlines with 15x10 bogarts with no problems.
We both did have to roll our fenders. He had to bang in the inside behind the wheel just a tad because he rubbed.
Old 11-22-2004, 03:22 PM
BTLFEDSS's Avatar
Thanks, The rolling of the fender kind sounds like it could get ugly,was it hard did you do it your self and how does the paint hold up
Thanx BTLFEDSS
Old 11-22-2004, 04:08 PM
Derek98z's Avatar
someone makes a fender roller that I hear works good. You can always do the baseball bat method also. My paint held up fine and I actually had to hit some spots with a hammer.
Old 11-22-2004, 04:10 PM
BTLFEDSS's Avatar
Thanx again
Derek98z's Avatar
Here is a pic of my buddies car in fact. The tires are et street 26 x 11.5 x 15 I believe.
Old 11-22-2004, 04:13 PM
Derek98z's Avatar
And another showing how far it tucks in
Old 11-22-2004, 07:15 PM
BTLFEDSS's Avatar
Wow both of ur cars are hot u guy's must get alot of looks.but my next question is do you just stick the bat between the tire and wheel lip and have some one hold and roll the car slow?Any help with this would be awsome
Thanx
Old 11-22-2004, 07:19 PM
Slow Z28's Avatar
thought i remember reading somewhere to take an x-acto knife and slice the paint right along the underside of the lip so that when you roll it it doesn't chip the paint, just seperates at the "cut" line.
Chris
Old 11-23-2004, 04:53 AM
2MuchRiceMakesMeSick's Avatar
Chris
Yep as well as put several peices of maskin tape all along the inside of the paint. 3/8s from the wheel well should be sufficient for the cut.
Old 11-23-2004, 03:06 PM
BTLFEDSS's Avatar
Ok so tape line slice a line in the paint stick the bat in and roll car basicly correct?
Old 11-24-2004, 10:20 AM
yes as far as i understand this is how you do it. cut 3/8 from the wheel well on the lip. Then tape it up with masking tape. Then try to get teh rear end as low on the ground as possible (as many freinds as you can put in teh back) And then SLOWLY roll the bat.
