will 18/10 wheel rub up front
Old 11-30-2004, 08:57 PM
SLP/Drew's Avatar
Exclamation will 18/10 wheel rub up front
my question is pretty simple if i get an 18/10 wheel with 275/35/18 will that rub...ive had some guys say yes and others say no???
Old 12-01-2004, 09:45 AM
Onebadwedge's Avatar
I have had my OEM Z06 18's on the front with 295/35/18 on them.
The only part that rubbed was when I would turn the wheel completely
in one direction. It would rub on the front part of the inner fender guard.
I don't know what it's called but it's that black plastic that covers the
entire front fender wells. I could only fit my pinky between the tire
and the top ball joint(?). I really had to jamb it in there and I have skinny
hands. I drove around like that for 2 weeks and there was no rub on
the metal. No "clean" spot. It was all still very lightly rusty. The rubbing
at full lock was very minimul. All it did was keep the black stuff clean.
I only turn at full lock when backing out of a parking spot. Almost never
when going forward. And of course never on the street because
you are going too fast at even 20MPH. Mine are 58mm offset, OEM 2002 Z06 rims. I could run them on the front all the time, but I can't find anyone
selling just the 18's from a similiar car. But then again I'm not really
trying too hard with x-mas around the corner. I will eventually have 18's
all the way around because I know that the rims/tires I have will
fit with very minimal rubbing.
I did a couple of "quick" drives through parking lots, zig zagging back and
forth until tires were howling, drove in circle until tires howled....still no rubbing.
The biggest thing is the offset.
good luck
Old 12-01-2004, 12:02 PM
Todd@AZPowerAndSound's Avatar
with 275-35 you are fine...as long as your offset is around +50 to +56
Old 12-01-2004, 12:31 PM
SLP/Drew's Avatar
thx...the offset on the 18/10 is 41mm
Old 12-01-2004, 12:33 PM
my apologies... you can get down to about a 40 offset on a 10" without issue. As long as you arent on sportlines
Old 12-02-2004, 02:49 AM
popocamaro2's Avatar
im freakin rubbing up front with 275/40/17`s how i have no clue these are new tires with balance & alignment but it requires turning almost all the way too since we are talking bout wheel rub anyone else with that problem with these tires on the front of their SS?
Old 12-02-2004, 09:47 AM
original or aftermarket SS rims? If they are aftermarket, they could be the wrong offset.
Old 12-02-2004, 09:46 PM
777's Avatar
Originally Posted by Todd@DiscountTireDirect
I promote big fat yellow smoke burnouts!
i wonder why $$$
