I Just Want A Couple Opinons On These Wheels
Old 02-27-2005, 06:34 PM
SLEEK00SS's Avatar
Default I Just Want A Couple Opinons On These Wheels
I am going to buy some rims in the next month for my 2000 SS. Will I be able to fit 17X10's all the way around comfortably? Or would I be better off going with 17X8's in the front and 17X10's in the rear? Also, what size tire would go well with either rim choice? I really appreciate any help. Thanks!
Old 03-01-2005, 11:27 AM
Xsta Z 28's Avatar
17" x 10" fit up front with the right offset, the next question for you is what sized tires?
Old 03-01-2005, 11:35 AM
Bad Blu Formula's Avatar
If you're looking for handling, don't go with wheels that are so much different in width. Keep the widths close. 17x9s and 17x10s would be great. Even better would be 17x10s all the way around with a 285 tire up front and 295 tire out back.
Old 03-01-2005, 11:56 AM
abadss's Avatar
i've got 17x9.5 up front with a 275 tire, not issues, even with a eibach sportline kit. i have 18x10.5 in the rear with a 285 tire, could go up to a 305-515, looks great, no fitment issues. what kind of wheels you looking for?
Old 03-01-2005, 09:57 PM
SLEEK00SS's Avatar
I plan on getting Smoothie II. They only offer a 17X8 or a 17X10. I would like to go 17X10 all the way around with a 285/40R17. I just wanna make sure it will fit ok and look good. The offset would be 38mm.
Old 03-01-2005, 10:45 PM
SRfastZ's Avatar
my homeboy is runnin Smoothie II 17 by 10 all around and they fit good, tires size is 275 40 in front and 315 35 in the back ...they look good you cant even tell they are 10 up front so i think you should get 17 by 10 all around
17 by 8 is just tooooooooooo small for an f-body
Old 03-01-2005, 10:55 PM
LS1Tech Co-Founder
Nine Ball's Avatar
17x8 isn't too small for an f-body. Stock wheels are 8" wide. I had 18x8s on my Formula and it looked great.
From the outside, you can't tell the difference between an 8 or 10 wide wheel. Our wheels have the additional width on the backside of the wheel.
tires would be cheaper with 8s. Steering would take less effort also.
Old 03-02-2005, 09:15 PM
SLEEK00SS's Avatar
My stock SS wheels im pretty sure are 9" wide already. They are 17's right now. As long as I know 17X10's with a 285/40 will fit all the way around, I will go with those. Thanks for everyones input.
Old 03-02-2005, 09:40 PM
LSUxBlake's Avatar
I have 17x10 smoothie II's all the way around on my car. 285's all around as well and they fit very nicely.
Old 03-02-2005, 10:15 PM
SLEEK00SS's Avatar
They look really nice man!!!
