BFGoodrich T/A KDW OR Kumho ECSTA MX
Old 03-14-2005, 04:47 PM
y2kmaroonz's Avatar
Default BFGoodrich T/A KDW OR Kumho ECSTA MX
Just wanted some input on these 2
Old 03-14-2005, 05:12 PM
luv2spd's Avatar
I have KDW's now and I really like them. Great handling and they grip pretty good.
Old 03-14-2005, 11:05 PM
lsx24's Avatar
BFG KDs stick well and are generally less noisy at the limit, but I went with KDWs because they have slightly more treadwear.
Old 03-14-2005, 11:15 PM
Spenser309's Avatar
http://www.discounttire.com/dtc/find...36&rd=17&ar=35
work like a dream in the rain.
Old 03-14-2005, 11:40 PM
12stones's Avatar
Both are good tires from what i hear, althought if i had to pick i'd go with bfg kd's
Old 03-14-2005, 11:56 PM
1 BLOWN V8's Avatar
I would go with the KDW tires.
Old 03-15-2005, 12:43 AM
ynneK's Avatar
tirerack did a test on the KD and MX's (not user reviews, actual test) long story short, the KD's edged the MX's out in the dry traction, but the MX's were better for wet traction. And it rains alot in Oregon.
MX's are about like $170? for per 275's..
Based on that, my next set is going to be MX's..
Old 03-15-2005, 08:24 AM
Xsta Z 28's Avatar
I have both, and like them both. The KDW's are quieter. The Kuhmo's are HEAVY . . .
If money was the concern, I'd buy Kuhmo's again . .
If I was looking for a good tire, I'd buy the BFG's.
Old 03-15-2005, 03:39 PM
denton needham's Avatar
goodyear gsd3's better than kdw
Old 03-15-2005, 05:05 PM
y2kmaroonz's Avatar
Input is good
Old 03-15-2005, 07:20 PM
Slart's Avatar
I have the MXs on the rear of my car. I am not that impressed, I didnt think they were any better than the stock tires.
At first they were much better than the worn out stock tires, but after the MXs were also worn out I put a set of stockers (off a friend's totaled car), and his stockers performed just as well.
My current opinion is nitto drag radials in all corners is the only way to go. The treadwear isnt that much worse than the MX, and the traction in both wet and dry is much better.
A good deal more road noise because of the rocks sticking to the rubber though.
Old 03-15-2005, 09:25 PM
Shuck's Avatar
The MX's are good tires for the money.
Old 03-30-2005, 07:40 PM
Jimmy P's Avatar
I just had some Ecsta Mx's installed in the front. It was raining like hell outside, and they felt prety good for a tire thats supposed to be mostly for dry weather. Cant comment on how they hook though, because they aren't in the back. The installer recommended that I put them in the back, because my Nittos look prety worn, but I will just put Nittos back there.
Old 03-30-2005, 07:42 PM
SSNISTR's Avatar
Get the KDW's, lighter and better bulid quality....and nicer tread pattern IMO.
Old 04-04-2005, 04:23 PM
lrk322's Avatar
Whats the dif between the kdw and kdws? Is it worth the extra $40?
Old 04-04-2005, 04:30 PM
y2kmaroonz's Avatar
kdws are all season
Old 04-04-2005, 06:55 PM
luv2spd's Avatar
I would say that it is. The KDW will give you a lot better grip and the kdws look like crap imo.
Old 04-04-2005, 11:34 PM
OctaneZ28's Avatar
Another happy KDW owner here!
Old 04-05-2005, 06:31 AM
PA Z06's Avatar
I have a set of Mx on the back and they are just ok, but they were cheap, im gonna try BFG's next
Old 04-23-2005, 09:55 AM
JasonWW's Avatar
D=Dry
W=Wet
S=Snow
KD is high performance dry
KDW is high performance dry and wet
KDWS is all season snow tire.
I would recommend the 275 555RII Autocross tire over the drag radials. They are virtually the same except the RII's use a stiffer sidwall. The ride is still smooth and are very quiet going down the road. Now if you drive over small rocks, they do sometimes get thrown up due to the stickyness of the tire. It's no big deal, though.
They are truly superior. On all 4 corners you will be able to corner, brake and accelerate like you never have before. Just incredible. They're a true R compound and so far I have gotten about 5K from my 315 rears. They are loosing tread in the middle, but still grip well in the rain. The fronts are still going strong, maybe get 10K out of them. I can pretty much out brake everybody.
