Will 13" Wilwoods fit under 17" ZR1 Rims?
Location: Fairfax County, VA (You know you're here when you see the bad roads)
Anyone know if the wilwood Superlite 6 Piston kit with 13" rotors will fit under a set of AFS 17x9.5 ZR1 front rims? Did a search but couldnt find anything.
Thanks
Thanks
If im not mistaken you need atleast 2" between the rotor size and the wheel diameter, and to be on the safe side subtract another inch from the rotor...so that means a 14" rotor...i think itd fit
Thanks
Thanks
SSU'S Vice Mod
Originally Posted by Xsta Z 28
Just FYI TT2's do not fit over 13" brakes . . . . not really applicable, but just saying . .
Good thing you said that though!!!! That's probably what I'd do. Plans just changed possibly,
