Installing New Wheel Studs
Old 07-08-2005, 01:31 AM
burnout04's Avatar
Default Installing New Wheel Studs
I was wondering if you can install new wheel studs in the rear by just smacking the old ones out with a hammer, and then bolting the new ones in, pulling them through by bolting on the rims. A shop just told me I couldnt do it that way and the axles had to be removed and then have the studs pressed in. So what do i do?
Old 07-08-2005, 08:56 AM
Xsta Z 28's Avatar
You can use and old lug nut and some washers to re-install a lug stud.
The trick is geet the lug out between the brake shield and the hub, although I hear if you ahve traction control there is a little plug in the sheild you can remove.
Old 07-08-2005, 10:17 AM
Charging TA's Avatar
When installing the new one dont just only use a lug nut to pull it, put a few thick washers on to it just to get it all the way.
