10.5 Wheel with 7.25 BS
Old 08-26-2005, 05:09 AM
Shinsetsu's Avatar
Default 10.5 Wheel with 7.25 BS
How will they fit? Will it look like poo? Would a 275/50/ tire go good on it ?
Old 08-26-2005, 12:36 PM
Shinsetsu's Avatar
anyone?
Old 08-26-2005, 06:49 PM
blaSSt's Avatar
Assuming you are wanting these for a Camaro?
7.25 BS is equivalent to +51mm offset. They should fit well inside and be pretty close to the fender.
You did not quote the wheel diameter. If it's a 15" wheel 275/50/15 will be ok but you could go to a wider section width (295).
If it's on a bigger rim say 16,17, or 18 you will probably need a lower aspect ratio.
Old 08-26-2005, 06:59 PM
Tally TransAm's Avatar
that wheel is gonna stick out a little, but not crazy
a 15x10 weld wheels is usually run with a 7.5" backspace. so you moving the wheels out .25" with the 7.25 backspace, and adding .5" on top
Old 08-27-2005, 01:31 AM
Shinsetsu's Avatar
Sorry, it is for the Camaro and it is a 15" wheel.
The wheels are centerline auto drags.
so they will stick out 3/4's of an inch out of the wheel well?
Old 08-27-2005, 07:36 AM
blaSSt's Avatar
They should not stick outof the wheel well. Depending on tire selection you may have to roll your fender lip.
Old 08-28-2005, 12:18 AM
Shinsetsu's Avatar
I was wanting to run a 325/50/15 MT ET street radial. How would that look?
Old 08-28-2005, 12:17 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Look at the pic in my avatar... now imagine those tires and wheels pushed out a little bit. They will be flush with the lip. It can work.
Old 08-28-2005, 12:33 PM
Shinsetsu's Avatar
ok what about running a 275/50/15 on it for now and then later on get a 12 bolt or a 9 inch, and get it narrowed......how far would i need to get it narrowed?
would I be better off getting it narrowed more and getting a different backspacing?
Old 08-28-2005, 12:37 PM
LS1Tech Co-Founder
Depends on the tire, some 275-50's won't fit on a 15x10. Depends on the brand.
Old 08-28-2005, 07:46 PM
Shinsetsu's Avatar
a M/T et street or the radial
Old 08-28-2005, 08:59 PM
LS1Tech Co-Founder
Check around, I think Derek98Z ran 275-50-15 Nittos on 15x10'. If you ask around you can see what folks did.
Quick Reply: 10.5 Wheel with 7.25 BS
