what would be the best tire to use for street use on a 18x13 in rim
I am insearch of the stickiest tire that will fit on an 18x13in wheel. I don't care about rain or snow traction, just as long as it is sticky. And where I can get a few miles out of them.
Yes, the nitto 335 will be pretty sticky with a treadwear rating of 100 ALSO, another option would be the Michelin pilot sport cup 245/35/18 with a treadwear of 80. So they will be wider and stickier. That's the route I'm going after I smoke these 335's up.
I meant 345 for the pilot cups. The nittos will have more give in the sidewalls but will give you a little rear end sway when you're turning suddenly. The Cups are roadrace oriented so they will give you great handling and with a treadwear of 80 they're going to be as sticky as you can get. Probably another full inch of contact patch over the nittos as they run skinny.
Most nitto users report anywhere from 5Kmi to 7.5Kmi on then with maily street use. Probably expect about 5K out of the cups. Performance comes at a cost no matter how you look at it.
I'm running 315/30/18 Michelin Pilot Sport Cup's on 18"x11" wheels for the rear of my Trans Am. I went with the Cup's because I didn't want to sacrifice cornering ability by running a drag radial, but I still wanted that drag radial like hook. Let me assure you... they grip something fierce. Yes, they will wear out quick, but no quicker than a BFG drag radial, I expect to get 2-3 years out of mine... only drive 2-3,000 miles a year.
Also, they do run a little large. My 315's look more like 325's, running the 345's would be insane looking.
Originally Posted by 93formto98T/A
Just what I wanted to hear....thanks houdini. Street compound tires aren't doing it w/725rwhp/740rwtq lol
Well then the cup's sound like a good choice, since I would lose a lot of cornering ability. and the 345' s will be on my zo6 with a mini tub.
and with the power I will be making, there really isn't a good option for me but a slick.
