After search, I'm still lost on the 315's fit
Old 07-07-2006, 12:59 AM
UGOTWS6D's Avatar
Default After search, I'm still lost on the 315's fit
I have read through the threads and searched and I am still confused to hell. I am wanting to get TT 2's with the 17x11"s on the back. I am wanting the 315 tires but I am worried about them fitting good. I have an 02 WS6 and do not plan on lowering it. Will I be ok with them going right on or will I need the BFH mod i've read about? My other question is on the look of them. I have seen numerous pics and they look great from the side and at an angle, but from the back end does the tire stick out on top past the wheel well or is the wheel still sitting inside?? I know it will stick out on down b/c of how the bumper is curved. If you have this setup or have seen it, does it look pretty good or does it stick out too much? Sorry about the thread but I guess I just need this spelled out for me b/c i'm more confused now than when i started. Thanks for any help guys!
Also, if i would do 18's on the back and 17's on the front, would that screw up the ABS system or anything??
Old 07-07-2006, 01:40 AM
NBMgreg's Avatar
315's differ in size according to brand, for instance, a sumitomo 315 is narrower than a BFG 315, but unless your running BFG GS-D3's, you should not have any issues fitting 315's if your not lowered, its lowering your car that brings out all the fitment issues.
tt2's look great on t/a's, that is why they are so popular, as the saying goes "everybody and there mom has tt2's"... if they stuck out too far, or looked out of place, there wouldnt be so many people with them. and every car ive seen with them look fine, the rear tires are flush with the top, or apex of the fender, and as you mentioned, the start to stick out as the bumper curves in from a rear angle.
going with 17/18 combo should not trigger any ABS problems, alot of people use that combo with wheels like zo6's. one problem i see with running 17's and 18's with tt2's is the dimensions, a 17x9.5 tt2 looks quite a bit different than a 18x10(max size) tt2, the spokes are more stretched out, and flatter, and the 17x9.5 might even have a bigger "lip", due to the smaller diameter. not sure if its the case, but if it was, that would look odd, you might be better off going the usual 17x9.5/11 route.
Old 07-07-2006, 07:21 AM
tbs98z's Avatar
TT2 17x11 w/7.75 bs is an awesome look for the rears,although if your lowered you are gonna need an adjustable panhard rod and you might wanna roll the fenders.
Old 07-07-2006, 07:33 AM
casey02ws6's Avatar
https://ls1tech.com/forums/wheels-tires/537292-315s-dont-fit-all-need-help-asap.html
Old 07-07-2006, 09:48 AM
UGOTWS6D's Avatar
Thanks for the help guys.....that cleared up all my questions and confusion. I'll probably go with the 17x9.5 and 17x11 rims. Thanks again.
Old 07-07-2006, 10:16 AM
842ta's Avatar
I run a 335/35 on a 11'' rim and stock rear supen. just removed the bump stops and the "BFH".
Old 07-07-2006, 10:33 AM
ICRAZY6's Avatar
I have Boyd Coddington Smoothie II's with 315 in the rear on 18" rims and fit like a glove. They are for sale too if your interested pm me. Kenny
Old 07-08-2006, 01:45 AM
hpjunky98's Avatar
Originally Posted by NBMgreg
BFG GS-D3's
Goodyear GSD3s not BFGs
