Lets see pics of 325+ wide tires on f bods
Search wont work for me, and im thinking about buying some custom wheels and sticking some fat tires on them. Ill prolly be going with some 18x10.5 Fikse Fm5's, i hear that the wheels are very wide and can take a 335+ tire, is this true? I want to see some pics of 325+ wider tires on cars please.
335's will not fit a 10.5" wide wheel nor will a 325. 315 is the largest you can run on an f bod without modification or custom backspacing on the wheel. To run a 315 you will need an 11" wide rim. I personally opted for the 315's because I didn't want the added stress from backspacing on my axles.
Originally Posted by quickneSS
I thought you could run a 315 on a minimum of a 10.5" rim. Correct me if I'm wrong.
lol
Originally Posted by NHRAMAN
seems like there aren't any pics of wider tires than 315's i guess.???
lol thats the main reason i posted, Fikse's are alot wider than they are rated, a buddy of mine has some 18x10.5's that are wider than my 17x11's.
Post some pics of 325+ tires please guys, thanks for the input though.
[QUOTE=LS1NewBe370]Fikse's are alot wider than they are rated, a buddy of mine has some 18x10.5's that are wider than my 17x11's.QUOTE]
10.5" isn't a rating... It's a mesurment taken from the inside lip, to inside lip where the tire will be mounted. Sorry but 10.5" is 10.5".
pics only please
I didnt start a thread to argue that I know a 315+ tire will fit on a Fikse 10.5 rim, I know it does so thats that. Thanks Carolina for the pic, thats the response Im looking for.
I had 335 pilots on my camaro. They stuck out past the fender, no way around that, unless you mini-tub. Between them rubbing, and the way they stuck out, their not worth putting on.
