back blowout..
Old 10-12-2006, 09:46 AM
Ryanols1on's Avatar
Default back blowout..
i have a 2000 trans am... i just got the 18X10 smoothie IIs and i got 295s for them.. if i GET ON IT.. will my rear end break?...what do i have to do to be cautious?..what are the downfalls of 295s?
Old 10-12-2006, 10:14 AM
SweeTbone's Avatar
No, your rear end shouldn't break. Only if you decide to let loose a 5K clutch dump. Which if you do, make a video of it and post it. The stories of a rear end breaking on the street and on street tires are very few. Street tires will almost always break loose and spin and not put the rear end in a bind.
Old 10-12-2006, 11:02 AM
Ryanols1on's Avatar
thanks for the info.. that eased my mind. thank you... i LOVE this forum.. such helpful people..
Old 10-12-2006, 01:43 PM
SSilverSSurfer's Avatar
but when you get ready to get a new rearend, please make a vid of a 5k dump, lol
Old 10-12-2006, 02:24 PM
Derek98z's Avatar
make it a 6k dump on et streets! Took me a dozen tries at the track to finally pop mine.
Old 10-12-2006, 05:24 PM
MannyZ28's Avatar
I have 315/35/17s on the back.
I have BMR Lower Control Arms with Poly bushings
I have a Spohn Adjustable chassis mounted torque arm
I have SLP subframe connectors
I have a UMI double adjustable rod ended panhard bar
If I motor along at like 3k rpm in first gear...and give it just past half throttle, my car goes sideways....all they way through 3rd gear if I don't let off.
Spinning tires = rear end lives!
Why my tires are spinning considering my suspension mods and the size of the tire...well....I am guessing it's coz the tires are old and worn out...lol. That different sized cam, long tube headers, LS6 intake...blah blah blah might have something to do with that too.
Either way, unless you're running slicks on the track, I don't think you'll be breaking your rear end anytime soon, just because of your new wheels and tires.
Manny
Old 10-12-2006, 11:19 PM
Cop Car's Avatar
most likely you have less traction than stock now
my 245 stock goodyears hoooked infinately better than my 315 toyos
Old 10-13-2006, 10:20 AM
Ryanols1on's Avatar
i just got my new tires today.. they look alot fatter than what i was imagining..they are 295/35/18... tell me what you think..
Old 10-13-2006, 11:48 AM
MannyZ28's Avatar
Yup...they sure look wide when you first get them. But out cars have the tendency to make even the widest tire look somewhat small.
Manny
Old 10-13-2006, 12:10 PM
Ryanols1on's Avatar
did you have any clearance or rubbing issues?.. and can i get a 1.5 in drop?
Old 10-13-2006, 07:04 PM
MannyZ28's Avatar
I had rubbing issues....
But nothing a big hammer couldn't fix. You should get a double adjustable panhard bar to center your rear end properly to avoid the fender lips from chewing up your tires when you have passengers in the rear or drive through dips in the road too fast.
A lot of guys lower their cars....mine is not lowered, but yet it is. It's a 98 Model, and they tend to sit lower than the 99 and up cars. My buddy has a 99, and mine sits at least one inch lower in the back than his.
Old 10-14-2006, 08:57 AM
UMI Performance's Avatar
A adjustable panhard bar will help any rubbing issues and I highly recommend one. If you need any help let me know.
Thanks!
Ryan
Old 10-14-2006, 10:54 AM
Ryanols1on's Avatar
do camaros and trans ams have the same funder wells or whatever?... does everyone have rubbing issues with 295s?... and if i drop it will that be an issue?
Old 10-15-2006, 11:50 PM
i dont have rubbing issues with the 315's maybe im just lucky, i have a PHr(non adj.) i need to get an adj. one, i'll talk to you ryan
Old 10-17-2006, 12:01 PM
Ryanols1on's Avatar
my tires will kinda stick out a little past the body.. if i drop it 1 1/2 in.. will it rub the body?... or will it stay stiff enough to not rub?..
Old 10-17-2006, 03:11 PM
an adj phr will help that out
