Tires for the front after Nitto DRs, does it even matter?
Hey, Ive decided to get some Nitto DR's on some TT2's, any recommendations for what tires to get in the front? Does it even matter? I just dont know what to get, lol.
I only use the Nitto road race tires up front. 275/40/17 size only. They are just as grippy as the drags but with a stiffer sidewall. Super good at braking and cornering. They will last longer the the rears and match them in looks. Your car will stick much better with them than regular street tires.
Originally Posted by davered00ss
Nitto makes a 555R you can use on the front Then use the 555R extreem drag radials on the back.
Originally Posted by Trust
Those are the exact same tire. I think your talking about the 555RII's for the front, those are what the other guy is talking about. Personally I would just run regular 555's up front, unless you Auto-X on the street. I also think the stock brake setup is the choke point for brakes at this point more than the tires.
Auto-X on the street is pretty much the same thing as driving on the street. They are just good sticky tires that will make your car grip better than all the other cars on the road. Vette's included.
I tried the 275 GSD3 on the front, but found they were too soft. Even at 50 psi they felt spongy and responded slowly. I sold them locally and went back to my RII's.
Your right about the brakes. The stock pads suck. I could only lock the front tires at 45 mph with the RII's. Anything faster and the pads couldn't grip them enough. Once you put a better pad on the car you will get better braking ABOVE 45mph as well. This isn't a reflection of the tire, but of the brakes. Everyone should go out and upgrade the pads.
"Nitto makes a 555R you can use on the front "
Just to clarify, Nitto makes 4 types of tires for our cars.
Nitto 555 - regular old street radial. I've got a set of 4 I bought in 2001 that have probably 40K on them and they STILL look new.
Nitto 555R - drag radial, you can even put 4 on all corners
Nitto 555RII - autox , road race however in my experience this tire is identical in performace at the drag strip to the 555R. I love this tire on all 4 corners, especially in autox and street driving. Expect 10K at the most out of them and be careful in the rain.
Nitto NT-01 - new tire from them, even stickier than the the 555RII but really not intended at ALL for street unless there's zero chance of rain in the forecast however they do STICK and provide a harsher ride. When I say stick I'm referring to cornering abilities, I honestly have not tried this tire at the drag strip.
My $.02.
My $.02.
I've run both the RII and the DR until they were smooth and they stuck like glue on a wet road. Just have to watch for the puddles.
These 2 tires are practically the same except the side wall is stiffer in the RII. I'd run them at all 4 corners as well, but I'm running a 315 in the back and they don't make the RII in 315. The DR 315 is too soft feeling and doesn't respond to input as well as the RII so I switched to the GSD3 315 in the back.
Anyway, you can't go wrong with the RII up front. The regular 555 is OK if you want a tire that lasts longer, but it's not as stable at freeway and higher speeds. It has a similar looking tread pattern as well.
Pontiacerator
I have issues if there is any moisture with my Nitto DR's. But they are better than other DR's for sure.
I am running BFG KDW's up front and Nitto DR's on the back with my TTII's.
