DD Drag Radials. M/T or Nitto?
I'm looking for a drag radial that will be pretty much street use only. Maybe track one time a year. So I need a good traction radial yet be good for a Daily Driver in the rain, and get decent amount of miles out of it. I have stock Salad shooters so Nittos would be 245-50-16, and M/T would be 255-50-16.
Thanks in advance!
Thanks in advance!
Originally Posted by davered00ss
Nitto's don't hook any better than street tires.
I went from 295 Kumhos to 305 555RIIs and the differnece was literaly like Night and Day!!! The Kumhos would go up in smoke at almost any speed below 45mph, but the Nittos hook like Heck!!
And cold Nitto's on the street?
Originally Posted by ls1muscle
Nitto's suck when it's cold outside, as does any tire. But when it's warm out they're 10x better than street tires.
I have a H/C C5 A4 with 3500 stall. The Kumhos were fine before the heads (3.76 0-60mph), but after the heads, I could never get below 4.1 due to tremendous wheel spin no matter how I launched. After the Nittos, with the tires warm (read; short burnout) I ran a best of 3.37 0-60mph with just a small amount of wheelspin. (All runs with a G-tech pro.) The Nittos just flat out HOOK for me!
And since I got the R2s, the last trip to the mountains a couple of weeks ago was a BLAST!!
I have run Nittos for a while and you can get 20,000+ miles out of them if you do it right. Other DR's won't last much beyond 8,000 miles. Some won't last beyond 3,000. Frankly, that's not daily driver territory, these are more like cheater tires made to win drag radial class racing with no actual intent of being used for daily driving.
Unless you're made of money, you're stuck with Nittos at best for the street.
I too am looking at these two for my car. I have ran the Nittos on my current car and my previous a4 car. I have beat the **** outta these tires for miles, I am talking 15k+, hundreds of burnouts, and not short ones.
To you people that say they're no better than street tires, and that they suck in the cold, your dead wrong. My car is making 446/411, and last nite it was in the 40s for sure. I could just jab the throttle in 2nd at any given time and the car would send them up in smoke and go sideways. This was at 20psi after 40 miles of driving! I went out to a backroad just to see...and dropped them on down to 18, and did a 8 sec burnout, took off at 3k bogging it purposely, then rolled into 1st. It hooked rather well, and the main thing I was concerned about was the hard 1-2 shift, which turned out fine too.
Point is ANY tire sucks in the cold when they are cold. Put some heat in the Nittos and they will out-perform ANY street tire by an enourmous amount. I also 60ft'd 1.64 with them in my a4 car FWIW. 1.82 in my current m6 car with stock suspension and they were significantly past the TWI.
There's no way I would run any street tire over these. But I do think the MTs will be alot better for the track and for street races. I just have to make up my mind if the trade-off in mileage, getting caught in the rain, and any handling differences are worth it to me.
To the original poster, good luck in your decision, it's a hard one, I know.....
