any drag wheels that dont require caliper grinding?
my calipers are nice and painted...why would I want to grind the calipers??
any drag wheels offered that dont require grinding?
Erik
Erik
Originally Posted by DopeFedZ
Bogarts.
http://img296.imageshack.us/img296/417/d10sy3.jpg
I just run a 7/32nds spacer.
Convo pro's, if you get the right offset. They stick out of the wheel wells a bit though, not sure if that bothers you. I had a pair of 15x8.5 and 15x4's, none of them required any caliper grinding.
Moderator
Centerline Convo Pro's do not require grinding if you use the 15x7.5 with 5" BS or the 15x8.5 with 5"bs.
You can see 2 pages of pictures of both these sizes as well as 15x4 at the link below:
http://www.wheels.ls1tech.com/galler...&g2_itemId=184
John
John
im looking for a set of rear drag wheels for the track..should I just invest in some 16" **** rims with some MT's on em, or spend the cash on a nice set of drag rims and wider MT's?
depends if you want all looks, all performance, or both.... i use 94 z28 wheels (salad shooters) which is the lightest 4th gen wheel, with MT ET Streets.... i'm thinkin of swithin to convo pros b/c they look friggin sweet, but you can grind the caliper and repaint them and go with weld draglites
well I already have pro stars for the fronts....I run a spacer for those to fit without grinding....i have sexy *** TT2's for my DD, this is for the FEW time I will go to the track..I want sticky *** tires....
hmm ok, well thank you for the input..maybe ill just grind and repaint...how much do I need to grind the rear calipers to fit say some 15x 8 pro stars in the back?
Originally Posted by 02White6.0
Look in my sig man, Im running Weld Draglites all the way around and none of my calipers are grinded! 15x3.5s in the front with spacers and 16x9s in the rear
Not sure how people like em, but I just scored some 16 x 9.5 AR Hopsters for a good price off ebay with the special order 6 3/4" BS. As soon as I receive them I'm going to either mount 28" ET Streets or M&H 275/55-16 Drag Radials.
