18x10.5 c5 z06 - Spacers, BFH, or new wheels?
Old 02-12-2007, 08:55 PM
di0ck's Avatar
Default 18x10.5 c5 z06 - Spacers, BFH, or new wheels?
OK, I bought C5 Z06's 18x9.5 and 18x10.5 and the rears don't fit with the 295's GY GS-D3's i got for the back. REAR WHEEL OFFSET IS +58
I'm using Sam Strano drop springs and these wheels from Tomzwheels won't clear in the back, they rub the inner fender well on the axle side. This is constant rubbing, not only when turning or hitting bumps.
My question is should I run a small spacer (like 10mm), should I just hit the areas that are rubbing with a sledgehammer (and what would that harm), or should i see if Factory reproductions or another wheel from Tomzwheels would have an offset that would space the wheels out slightly more?
Old 02-12-2007, 09:07 PM
Turo's Avatar
Depending on just how much its rubbing, I would first do the BFH mod. If you still don't have enough room then maybe add a small spacer, as long as its small enough so you don't have to roll the fenders or anything.
Old 02-12-2007, 09:14 PM
Trunion King
bene's Avatar
I went w/ LMP, they sell Z06s 18x9.5/10.5s w/ 53mm offset. I have no rubbing issues.
Old 02-12-2007, 09:32 PM
vatechguy3's Avatar
what offset are you currently running on the c5's??
tony
Old 02-12-2007, 09:47 PM
michaelg589's Avatar
my 18x10.5s have a +58mm offset. there was no rubbing, but I am also at stock height. I put a 5/16" spacer on the rear, just to bring it out a little (it looked a little sunken in), and there is plenty of room everywhere. The 5/16" spacer is about 8mm thick.
Old 02-12-2007, 11:06 PM
di0ck's Avatar
tony
im running +58 offset
Old 02-13-2007, 12:48 AM
di0ck's Avatar
so do people always start with BFH mod, or is it bad and they get spacers first?
Old 02-14-2007, 08:52 AM
Xsta Z 28's Avatar
I ran 58 mm offset on my convertible, and had to do some minor BFH. I then later added 5/16" spacers, but I'd recommend longer stronger studs with a spacer that thick.
Your "extra" rubbing I'd equate to the GSD3's since they run very wide.
Old 02-22-2007, 07:13 PM
di0ck's Avatar
sorry i havent posted here in a while, i still havent resolved this due to lack of time.
I will be trying some BFH on saturday morning, and will recenter my PHB.
Since I plan on road racing and canyon carving often, though, i think a spacer will
be necessary also. But finding the safest spacer and the right thickness will be a task.
Can you help any? what kind of spacer did u use? I want something safe enough for track use... would that be the kind that bolts to the existing studs and has it's own set of studs? How bout the H&R TRAK+ wheel spacers? http://www.hrsprings.com/site/products/trak.html
Old 02-22-2007, 07:32 PM
408Maro's Avatar
i also have 58 offset on my z06's and using a 5/16 spacer due to rubbing. i dont like the sounds i hear in the back from it moving a lil,where can i get the longer studs from? thank you
Old 02-22-2007, 07:57 PM
Screamin99TA's Avatar
Sorry,but what does BFH stand for?
Old 02-22-2007, 08:07 PM
Rebob5's Avatar
Big F@%king Hammer.
Old 02-23-2007, 05:56 PM
di0ck's Avatar
ok, thanks n00bs... some real help now please?
Old 02-23-2007, 06:13 PM
SS DNA's Avatar
Whats or who is LMP???
Old 02-23-2007, 06:30 PM
JasonWW's Avatar
http://www.lmperformance.com/
Old 02-23-2007, 06:42 PM
slick1851's Avatar
Ewww.....58mm offset is gross!
Old 02-23-2007, 11:47 PM
96lt1m6's Avatar
i got my rear wheel stus from chevy,they were for the 97-99c5 wagon wheels those studs are 10-12mm longer than the f-body stud,still need the BFH mod by the lca area,now that i have the flat stars i needed a spacer on the rear 5/16
Old 02-24-2007, 08:48 AM
JasonWW's Avatar
Where did you guys get your 5/16 spacer from?
Any problems with vibration?
Old 02-24-2007, 06:48 PM
408Maro's Avatar
i got mine through a tire shop that i had my tires installed but they had to order them through america tire co. and i do think my car rides like shyt. so i just got into chevy and ask for the rear studs for a 97-99 c5? thanks
Quick Reply: 18x10.5 c5 z06 - Spacers, BFH, or new wheels?
