best air psi for nitto 55r drag on the street
hey guys what is the best psi on 275-40-17 nitto 555r drags?
it will be on my dd camaro
also whats the best psi for the track
Anything over 28psi cold and they seem to wear out the middle much faster than the edges. I like 27psi cold on the street for best wear. 16-20psi at the track depending on conditions.
Originally Posted by shaun
well is that ok for the highway runing that psi?i normaly run between 31-32psi in my street tires and i nornaly cruise about 80 on the highway
Run 25-26 if your worried. Running 31-32psi and the centers are definitely going to wear out before the edges like already said.
That much pressure and you also negate alot of the "stoplight" traction benefits . That's if you engage in such activities .
