Will these fit?
Will these fit?
Just wondering will these fit?
Wheel Size_____Bolt Pattern______Offset
19x8.5__________5x120__________35
19x9.5__________5x120__________40
20x9____________5x120__________20
20x10___________5x120__________25
I know the 19x9.5 will fit no problem. BUT I really want to run 20's all the way around. Is there any way with these wheels? Either 20's all the way around or a 20x10 & 19x9.5 set up.
THANKS!!!!!!
If neither above will work I want to run a staggered setup with 19's BUT once again the offset for the 19x8.5 rim is 3mm off. Will this be a problem or can it be trimmed down 3mm?
THANKS!!!!!!
That offset is too low. You need atleast a 35 for the rears if they are going to be 20's. The 19's will fit fine though.
I heard of people doing it for their GTOs. I dono if I want to risk that or not. Especially on these rims. They arent cheap at all. The only reason I want the 20's is because the lip is about 1" bigger on them compared to the 19's.
I want to keep the rims on the "down low" right now. I will be the only F-Body that I know of with them.
Whats up with the sig? Someone steal your wheels or what??
