Summit Star wheels
Old 05-02-2008, 09:53 AM
TurbopigB4C's Avatar
Default Summit Star wheels
Will 15x10" 5x4.75" bolt pattern with a 6.5" backspacing fit on a 99 fbody with 275-60r15 dr's?
Old 05-02-2008, 11:01 AM
Photochop's Avatar
nope. only summit star wheel that fits is the 15x8 5.5" bs. unless of course you wanna narrow your rearend an inch on each side.
Old 05-02-2008, 11:12 AM
Anyone know any reasonably priced rear wheels to fit a 275-60r15 draig radial tire
Old 05-02-2008, 11:38 AM
bluebeast's Avatar
the greg welds are said to fit......
Old 05-02-2008, 12:16 PM
Camaro396's Avatar
They will fit but stick out an inch, much like the 15x10 welds with 6.5 bs will. Trans ams and firebirds can sometimes pull it off, but camaros cant. Also greg weld rears wont come out for a while.
Old 05-02-2008, 12:19 PM
Photochop's Avatar
You can mount a 275/60/15 on those 15x8s. They fit no prob.
Old 05-02-2008, 01:13 PM
will there be any noticeable performance difference between the 15x10 and 15x8 if i were to be using the same size tire anyways?
Old 05-02-2008, 01:14 PM
Camaro396's Avatar
15x10s weigh more. Alot more rotating mass.
Old 05-02-2008, 01:21 PM
cool ill just go cheap then and get the 120 a wheel 15x8 summit stars
