View Poll Results: What are the better DRAG RADIALS??
MT ET street tires
40
78.43%
Hoosier DOT drag radials
11
21.57%
Voters: 51. You may not vote on this poll
best DRAG RADIALS? not SLICKS!!
I drove on my hoosier qtp's once in the rain, wasnt much fun, probly wouldnt be much difference with those 2 radials. Like said, get an extra set of wheels and mount them, they'll last alot longer too.
I disagree. They may work for you on stockish power, but any more than that and they won't be consistent for the OP, look at his sig.
You'll have much better luck with the MTs or Hoosiers at the track over the nittos with what you listed in your sig. 400 rwhp is pretty much the upper threshold of what the nittos can hook. Best I did on nittos with this power level was a 1.78 60'. That was once out of about a dozen mid 1.8 60's. The same car on 255/50 mickeys mounted on stock 16" wheels cut consistent 1.70 60s, very stockish suspension, 3500 TCI stall and 3.42 gearing with the magic stick 3 cam don't mix well
